Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
For those who are interested in replacing the switch harness on a 933, it is really simple. Carefully pry up the 4 white porcelain igniters (use a cloth around plyers to protect the white part). Pull off the wires. Use a torx screwdriver to remove the 8 screws under the burner tops. Lift off the top of the range. This gives you access to the harness. Replace harness. On mine, the wires exited the harnesses toward the edge of the range. Make sure they sit down on the screw heads and don't move as you rotate the knob. Put the top back on, then put the torx back in and test. Easy-peasy.
SOURCE: One of my ignitors is constantly sparking. All the
Here is a tip that I wrote that will help you with that...
heatman101
