Question about MSI Microstar KT6 Delta (MS-6590) Motherboard
3x1GB 3200 wont work with kt6delta6590
I have 3 identical apacer 3200 cas 3 modules.
I ruled out defective rams or slots, by trying all combinations.
Bios recognises 3GB but Win XP is started, I get a weird blinking thingy in the upper left corner.
2 GB works fine
3 GB just seems too much.
thanks in advance
  • 2 more comments
  • Anonymous Jul 22, 2008
    I have the same problem too. Is there some patch for it? I can´t believe, that Steve and Bill, they haven´t any olution for it ;-)
  • Anonymous Aug 23, 2008
    I have the same problem?
  • Anonymous Sep 17, 2008
    bios update driver boot
  • BigDuke6 Jan 04, 2009
    I have exactly the same issue
  • 55 Answers
Often, Windows XP 32 bit will crash with more than about 2.5GB of installed memory.
Posted on Mar 02, 2008
GA-7VX memory error
Kingston manufacturer code on side of Ram Memory module, please. Need to know if it's compatible. Post back in a Comment.
http://hothardware.com/Reviews/Gigabyte-GA7VX-Slot-A--VIA-KX133/
Should be;
SDR Sdram at 133MegaHertz. (PC133)
LOW-density, unbuffered, Non-ECC, 3.3 Volt, 64Meg X 64 chip configuration, Cas Latency of 3.
Suspect Ram Memory you bought as the problem; especially if it is ECC, high-density, SERVER computer ram memory, sold on Eb** all the time.
Getting rid of surplus inventory, that NOBODY really wants.
Awaiting reply;
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
# of RAM slots
There are two models for this type of desktop, the first having only two DIMM slots, but that takes PC2700 Ram, you have stated that yours takes PC3200 which would make it the second model in which case your model has (4) DIMM slots, each slot is capable of holding a 1 GB stick of ram for a total of 4 GB. Your RAM specification is DDR PC-3200
Jan 12, 2010 | Computers & Internet
Can gigabyte 845 motherboard support 2gb ram
HI,
Yes the board should be able to support 2GB of RAM.
If there are 2 DIMM slots on the motherboard then it will support 2x2BG in each slot.
If there are 3 DIMM slots then the motherboard will support 3x1GB in each slot.
Regards.
Sep 14, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Intel D915GAV won't boot after installing CPU fan and RAM. Drives and fans spin, but no video or USB. No error beeps/messages.
Here are some questions and some things to try.
Is this a new motherboard or are you upgrading ram etc?
If it used to work then change things back to the way they were then change things one at a time until it stops working again.
I don't think the CPU fan would be the cause but you never know.
My guess is that the RAM is the wrong type or speed.
Sometimes if all the RAM modules are not identical you can also have problems.
If the ram is not all identical try different combinations of modules.
Have a read of your motherboad manual to see what the rules are for populating different banks.
If you don't have the manual you can normally find them online.
Jul 16, 2009 | Intel D915GAV Motherboard
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Memory upgrade oddity - compaq m2010us laptop
Compaq laptop have been known to be fussy with RAM, especially if you are mixing different brands/makes of RAM modules.
Try each RAM module one at a time to see if they work. Put these aside and when you have tested them all, then pair them up to see if they will work together. Try and use the same speed, brand and RAM size.
May 19, 2009 | HP Compaq Presario M2010US Notebook
Why does my comp didn't run Dual channel ?
Go into your BIOS and activate dual channel mode.
please also note that several motherboard required you to put the modules in certain slot configuration (such as in slot 1 and 3 or 2 and 4) but if you got only 2 slot then forget about this slot configuration.
Aug 30, 2008 | ASUS P5RD2-VM Motherboard
ADDED NEW RAM NOW MEDION WON'T BOOT UP
hi
i needs to the rams are in same speed. if it not you put a rams in same speed
next you need to study your motherboard manual it supports the ram speed.if ever this is ok. then your ram will be faulty
Mar 19, 2008 | Medion MD-1704 PC Desktop
MSI Microstar KT6 Delta (MS-6590) Motherboard Logo
112 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
