Question about HP PSC 2355 All-In-One InkJet Printer
That old paper Jam message again & again &.......
Hi Guys, great site
on closer inspection of above printer i found a small piece of broken plastic sat in the well below the ink cartridges. It looks like its part of a small tab or fin that sits pushing against the bottom corner of the printer block - just above the two visible white nylon gears and is attached to a spring.
Its the kind of part that looks like it could be a popular snapping point.
If youv'e managed to identify my problem area is it:
1. still possible to get this part, but more importantly
2. is it a real pain in the ass to strip down the unit and replace it?
Many thanks
Many thanks
Richard.
  • 1 more comment
  • Anonymous Mar 17, 2008
    I have had the exactb same thing happen to me. I am tempted to throw the printer away as repairing it sounds expensive. But if anyone has an answer I will be interested to know as well.
    Thanks
    Ray
  • Anonymous Mar 21, 2008
    yes me too, paper kept travelling through the machine, opened up lid and found small plastic lug lying in the ink tray, found that this had broken off a plasic section near two white gears. Super glue to the rescue, well at least for several operations then broke off again !!!! what a waste of money for just a 5 pence piece of plastic !!!
  • David Brown
    David Brown Apr 28, 2014
    This is a picture of the broken paper sensor attached to a spring at the right side.. Please someone upload a picture of how it's supposed to fit so I know how to epoxy it back again. Please!
    Novelist:
  • 188 Answers
Please click on the web link given below and perform the steps provided in the web link to fix the issue further.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00212225&cc=us&lc=en&dlc=en&product=422000
Please perform the steps provided in the web page carefully.
This should fix the issue.
Posted on Mar 21, 2008
How do I aline the paper sensor Someone jerked paper ouy causing the sensor to move?
Hi Paul
without knowing the make of printer its a bit of and open ended problem normaly the paper entry sensor will be found Above the paper tray towards the rear ................this can easily be blocked by a small piece of old paper(paper jam) mucking up the printer .....normally its fixed with clips hole and plastic wedge type arangment
Dec 22, 2014 | Office Equipment & Supplies
I face a paper jam a lot, what is the right steps to release it? I keep getting a paper jam message. I have opened up the case and inspected; removed the cartridge and inspected; no paper/paper jam found....
Turn printer upside down (yes), and check that there is no small paper or foreign objects inside the printer, ensure all door are closed, unplug printer power cable for 2 minutes to reset.
Jul 29, 2008 | Konica Minolta PagePro 1350W Laser Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
MF4350d gives a paper jam error when it has no paper in it.
I hired a technician who came to house and showed me where the paper jam was hidden... found technician on craigslist for $50 flat rate, came out on Saturday. He solved the paper jam problem in 20 minutes. One place to check for paper jam you cannot see until to look behind a hinged plastic flap above the cartridge area. Remove cartridge.Above the cartridge area is a width-wide plastic piece, about 1 to 1 1/2 inch wide from top to bottom, hindged along the top edge, moves but is attached along the two lower corners of the piece by small springs (one at each corner) to the housing of the machine. You cannot easily lift the plastic flap up to look behind it for paper jam until you remove the springs. I used forceps to remove them. Tweezers may work. Don't lose them! Once you remove the springs you can easily lift up the plastic flap (it is hinged) and look behind it into the crevices for any paper. That is where we found a small piece of paper. We needed a skinny forceps to reach into the crevice to get the paper out.
Feb 16, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Paper jam???
Follow these steps :
1.1
Remove all paper from the trays. This will prevent further jams during the clearing.
2.2
Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
3.3
Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
4.4
Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
5.5
Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
6.6
Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
7.7
Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
Oct 29, 2010 | Canon ImageClass D861 Printer
Paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Nov 06, 2008 | HP DeskJet 3930 InkJet Printer
Paper jam
Good luck,
Cory
Nov 05, 2008 | Brother Multi-Function Center® MFC-215C...
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Error - Paper Output Slot
Same problem with my mp600. Turns out I had a black twisty-tie in it. Must have fallen in from the top and ran through the printer as far as it could but got stuck on the way out. I pulled it out and presto!
Dec 24, 2007 | Canon PIXMA MP830 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP PSC 2355 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
