Question about Electrolux 23 in. ESL624 Built-in Dishwasher
Dishwasher not working properly
Hi
dishwasher model - esl 624 - integrated. Problem :our dishes are not coming out clean despite giving it the full programme 1 run even the simplest of stains i.e. residual coffee, the downward spouts on the upper arm have fallen off due to wear and the mesh at the base has also disolved. It appears to heat up fine and there doesn't appear to be a drainage problem. Any thoughts - or is this common ?
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Posted on Jul 30, 2008
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Tip
Dishs not coming out clean
It is a known fact that if you rince your dishs off before you place them in the dishwasher your dishs will come out alot cleaner. Stuck on foods can be baked on the dish causing the dish not to come out clean also by doing this it will exstend the life of your product because the passage ways for the sprayer will not get cloged giving a full pressure washing
on Dec 10, 2009 | Dishwashers
Electrolux ESL 43010 does not get hot ,and the dishes are not clean any ideas?
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately.
Oct 26, 2012 | Electrolux 23 in. ESL6114 Built-in...
My knemore dishwasher is not cleaning the dishes like it used to do and dishwasher is not cleaning itself also. I have this dishwasher for over a year and two months ago I had a pipe leak from dishwasher...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 12, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
Dishes are not rinsing properly they come out spoted and full of streaks.
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Sep 16, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
The dishes are not cleaned properly come out with a scum over them.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Beko 24 in. D3421F Free-standing...
Rinse aid is no longer being used up in my Whirlpool ADP5966. The level shows it as full despite about 10 washes since I last filled it. Dishes are noticably not washing as well as before.
You need a new water inlet valve. You are probably only getting half as much water as it takes to clean and properly rinse your dishes. Call or email us and we'll be sure to get the right part out to you right away.
Sep 09, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux 23 in. ESL624 Built-in Dishwasher Logo
268 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
