Question about Konica Minolta magicolor 2430 DL Laser Printer
How to install toner cartridge for konica minolta 2430 DL
I can't seem to get the old cartridge out to put the new on in.
  • 1 more comment
  • paysy Mar 05, 2008
    how to remove old cartridge and install new one
  • microdot Apr 03, 2008
    I needed to change all 4 toners. I got to the last one and opened the door only to find that the printer had not cycled to the proper toner. I closed it back and it now says please wait. It is not responding to any push of the menu button.
  • millertyme Apr 04, 2008
    we get error 2408 when trying to install new ink cartridges and the cartridges won't rotate.
  • 91 Answers
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I have put a new Magneta catridge in and i get a magnenta toner not installed message
Double check the way you put the cartridge. then try to turn of and on the printer.
Aug 13, 2010 | Konica Minolta magicolor 2430 DL Laser...
I put the cartridge in per instructions, but printer still says ''caution not installed toner check m toner''
Remove the cartridge -- is there any clear tape or cardboard "spacer" that should be removed from a brand-new cartridge?
Re-insert it. There should be a "click" or a "clunk" as it settles into its position.
Jan 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
787 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
