Question about Koss KS2503 System
Koss 2503 blows fuses
My KS2503 blows fuses as soon as the power is turned on. What's up with that?
Thanks
  • hdrick Mar 02, 2008
    My KS2503 system blows the fuse as soon as the power is turned on. What's Up?
You could be having problems with just that outlet  It might not be able to handle that much electricity.  Try the system on a different outlet.  If it still doesn't work, try the system on an outlet on a different fuse.  On an overloaded fuse something as simple as curling iron can blow a fuse.  If none of these work then it's probably a power supply issue.  If the power supply isn't grounding right, this could be causing the system to overload and blow a fuse.  The only way to fix this would be to replace the power supply; however, this might not be practical or possible.  I would suggest simply buying a new system, but if you're up to it go ahead and try to get a new power supply.
Posted on Mar 17, 2008
Suddenly blows fuse as soon as plugged in why?
Usually a fuse blowing immediately means there is a short in the amp somewhere.
Jan 04, 2013 | Koss KS2503 System
My dvd player koss ks2503 stopped working ,i changed the fuse but it still not working
Check the capacitors in the power supply and replace the ones that are large and/or leaking. They usually look puffed up on the top. Also check the solder connections on the power supply. Very common with these "KOSS" units.
Jul 18, 2011 | Koss KD250 DVD Player
DVD Tray stock closed Koss ks 2503
See if you can acquire the software upgrade that Koss engineers devised to solve the problem, I did have one(the upgrade) but misplaced the disc, if you manage to obtain it please e-mail me.
Art.
May 25, 2008 | Koss KS2503 System
NEED OWNERS MANUAL FOR KOSS KS2503 DVD PLAYER
I have a PDF of this manual if still needed?
Mar 07, 2008 | Koss KS2503 System
Koss KS2503 will not come on
You are better off buying a portable; u can get a magnovox DVD player for under $40 with DivX and connect it to the unit, and use it that way. www.kcwholeseller.com
Jan 02, 2008 | Koss KS2503 System
Koss KS 2503
hey,
have you tryed to clean the laser?
You can either buy cd's with brush mountet on it or you can
DO IT YOU SELF remove cover (carefull, high voltage inside, and laser product: so protect your eyes ) and clean the laser with some watter, or other cleaning liquid products?
;) /michael
DIY BLOG why pay when you can play
Dec 30, 2007 | Koss KS2503 System
KOSS KS2503 CODE
Don't need to hack it,you could call Koss??
Aug 14, 2007 | Koss KS2503 System
Koss KS2503 System Logo
166 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Carlos L. Burgos
Carlos L. Burgos
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
