Question about Lexmark X83 All-In-One InkJet Printer
Replacing empty cartridges
I have a Lexmark X83 V5.81 printer and I can not find my manual in order to replace the empty cartridges.1. How may I get another manual?2. Is it possible to pass on the instructions?
  • 91 Answers
If I schedule a print for my Lexmark X83 it feeds one sheet of paper straight through to the tray but does not print anything. No alarms anywhere on system. Same thing occurs if I ask for test print or...
Sounds like a clogged print head. In the lexmark printer software there should be a maintenance tool where you can try and clean the print heads.
By the same token the X83 is about 10 years old and well past the life cycle of most ink jet printers so if the troubleshooting tools don't get it back in order, it will be cheaper to replace than to repair.
http://www.lexmark.com/AP/service/info/multifunction/4403.pdf
Jul 09, 2011 | Lexmark X83 All-In-One InkJet Printer
My dealer said my color print cartridge was 3/4 full and had all 3 colors coming out but the printer says it is empty and won't print in color. What can I do? It is a Lexmark x83.
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Oct 13, 2009 | Lexmark X83 All-In-One InkJet Printer
Changing the ink cartridge.
I am going to assume that it is a X83.
Here is the link to the user manual. A detailed explanation with pictures starts on page 17...
http://www.lexmark.com/publications/pdfs/x83/engui.pdf
Jan 21, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X83 Problem
be sure to delete your printer and reinstall the printer cd back again but be sure there is only one printer install on your control panel .
Jan 05, 2009 | Office Equipment & Supplies
Printing out blank paper
Under your windows did you check at the printer settings.. maybe you set it to print with the color cartridge only and now its empty. Check and set it to use black cartridge.
Jan 04, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 missing parts
You can download the drivers from Lexmark website. If it is just the power cord, you may be able to find one from another piece of equipment that will work. But, if you lost the "brick" for the power supply that would be harder to replace. A new printer would probably cost less than replacing the parts. You can get a new Lexmark All-In-One for $60-$99 dollars. The print quality on a new printer would be better, and the cartridges are less expensive.
Sep 19, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83
open the door on the printer. YOu'll see both cartridges. Pull them towards you until they click, then pull them out. Replace with new:)
Jan 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
