Question about Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum
Dirt devil 12amp,Patent No.6571425
I have the above vaccum and does not pick any stuff from the carpet. Can you please advise me
    President:
  • 1,673 Answers
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Posted on Mar 02, 2008
  • trish anne Oct 13, 2011
    I just unwrapped a bunch of string or something from the roller it still isn't picking up-the hose haws suction (it feels like it) but won't pick up either-how do I unclog the dirt inlet by brush roller
How do you get it unclogged?
Posted on Sep 28, 2008
My dirty devil vacuum cleaner is not picking even the tinniest dirt off the carpet
Has the hose at the clearer head gotten clogged with carpet fibers, that is the common reason for this.
Sep 21, 2016 | Dirt Devil Vacuums
Vacuum doesn't pick-up dirt
It's probably not picking up because the belt is worn and stretched. With a new belt it will pick up a lot better. Here is the belts you need:
Dirt Devil FeatherLite Belt
Apr 07, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum Logo
375 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
