Only Power and door light comes on - no wash cycle selection
Hi Guys, at the end of a wash we discovered that only the power light and the door light were on. Normally I would expect to see the various lights that make up the selected wash cycle (Spin speed etc.) and a flashing Zero on completion. even after power off / on I only get power and door LED's and not last selected wash cycle. If I leave power off for > 3 mins then I can open the door. As an aside (may be helpful) we have noticed since we recently moved house that the washer does not seem to be spinning that well either.
  • John Thomson Mar 03, 2008
    Ahhh - I can see how you got to the rank of Guru, the thought had crossed the space between my ears but failed to stop on the way :-). The Model is a Zanussi fjdr 166 w. The problem I alluded to with regards to the machine not spinning correctly - my Wife thinks that the cloths seem to be coming out wetter than they used too before we moved a couple of weeks ago.
    Thanks Ginko, really appreciate the speedy response.
  • Washing Mach... Master
  • 19,396 Answers
To start the door sensor is faulty, in any case you have more than one problem. which is make and model?
Posted on Mar 02, 2008
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
