Question about IBM ThinPad R51 (2887EXU) PC Notebook
Vertical lines in lcd
My problem is so many vertical permanent lines is generated after random amount of time. some of them is a still different color of line like blue,green. and some of them shown like dotted vertical line moving bottom to upper direction. my email id is sify_.123@sify.com
  • Anonymous Mar 31, 2014
    Just moved to BT Infinity 1. Was not told that my Line Rental Saver would not apply but BT now charging monthly the difference between the Line Rental Saver amount of 11.75 and the full line rental of 15.99.
  • 91 Answers
Sounds like your graphic card is bad, try first to download updated drivers from the internet and see what happens, also try to connect an external monitor and see what happens.
Posted on Mar 02, 2008
I have a hisense 55" lcd and there seems to be some discoloration sometimes when there is dark colors and appears vertically. Usually looks like a greenish color and is not confined to any certain spo
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2014 | Televison & Video
Replaced 3 capacitors for start up issue, now have radom with vertical lines
You will need to replace all the capacitors in the output side of the power supply. It is possible you have other bad capacitors that are not bulging at the tops. The power supply generates a voltage used by the the video processor on the main board. If this voltage is out of whack, it can affect your video. I would recommend you check all power supply voltages for accuracy and ripple.
Jun 18, 2013 | Samsung LN-T4665F 46 in. LCD Television
I have vertical lines my 26TA1600 LCD TV. The lines seems to be permanent. What is the cause and how can I resolve it?
These vertical line are possible causes of LCD cables from the graphics card. There is no easy fix for this issue and normally requires servicing or part replacement. Try to contact your TV support people or consult you local technicians to diagnose it properly as it might be also the panel itself failing.
Apr 07, 2011 | Philips 26PF9966 26 in. LCD Television
Screen has multi color vertical lines, no discernable image...dead? Does same thing on muliple computers.
Vertical lines from top to bottom is the indication of bad LCD panel. It will get worst.
Jan 07, 2010 | Computers & Internet
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Nov 16, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Permanent vertical line down monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
It will change color with different colors and also if you push the screen at the top point. Don't play with pushing the screen too often as this may cause more to show up.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
We have a Samsun LN-T4071F LCD TV. The screen is all white and colored vertical lines. We disconnect the HDMI cable from the Dish box and the screen stays that way. We turn the TV off for a couple hours...
Do you have warranty on this unit?If warranty available contact servicer.
From your description problem is in the Digital board.
Replace digital baord.
Dont forget to Rate!
Good Luck
Dals123
Oct 22, 2008 | Samsung Televison & Video
Colored vertical lines
It is a tossup between a bad LCD panel and the logic board. The only way to tell for sure is to change out the logic board or have it tested on another unit. Checkout www.lcdrepair.us for instruction videos on that unit as well as parts.
http://www.lcdrepair.us/Installation.html
Jun 19, 2008 | Dell 2000FP 20.1" LCD Monitor
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
IBM ThinPad R51 (2887EXU) PC Notebook Logo
171 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
