Question about PNY Verto GeForce 6800GT, (256 MB) PCI Express Graphic Card
Traveldrive I was typing on Mac Mini intending to save to my travelrive. When I hit save, the traveldrive icon appeared and when I went to open it, I got a message that said "The document ?Demon Rising? could not be opened. The file is not in the right format." Then added that the file could be corrupted, truncated, or not in the formate that you think it is.   Is this file lost? Jay Nixon
  • 24 Answers
What type of file is this? What do you use to view it? How have they been saving in the past?
Posted on Mar 19, 2008
I am unable to import video from my Panasonic DVC62. when i connect it with my mac computer it doesnot show any icon in desktop. can u help me to solve this problem please.
Use a firewire cable to connect the camera to the Mac. Nor a USB cable.You will not see an icon on the Mac desktop.If iMovie does not open automatically then open iMovie.
Jan 07, 2012 | Panasonic AG-DVC62 Mini DV Digital...
Trying to install in Mac G4 OS X 10.5.8 a no go
Try reformatting it:
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Dec 30, 2010 | Memorex Mini TravelDrive - USB flash drive...
Intel iMac: disk does not eject, does not mount, makes no noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly. Now you mentioned that you used the drutil tray open command- if that is correct, then for your Mac Mini, that will not work, because that command is for drives with trays only.
In your case, you have slot drive in your Mac Mini so try the command line that I have provided below. It is just a slight modification from what you stated you tried.
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal application.
• At prompt, type: drutil eject and press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard).
If that procedure with Terminal does not work, there are two applications that you can try:
Disk Utility- You open the application, select the affected disc or the optical drive in the left sidebar window. Then select eject from the top of the Disk Utility menu. See if that work.
iTunes- Simply open the application, and select the eject icon at the bottom of the window.
Last but not least, I did notice you did not mention that you try this procedure:
Reboot your Mac Mini.
As the Mac Mini boots up, hold down all mouse buttons and keep holding them down until (hopefully) the cd ejects.
I am not sure if you have done all of these processes for ejecting your disc, but again these steps were not mentioned in your initial inquiry.
Let me know if these additional steps have helped or if they are in fact redundant.
Feb 02, 2010 | Apple Mac mini
I purchased a memorex 160GB traveldrive. I would
Things to ponder before deleting
Rather then deleting them right away, try moving the "day the files were uploaded" to another drive. Then try accessing the files on your memorex. Do the files and folders open properly? There not corrupt? Has the memorex hdd drive recreated the folder you just moved? etc...
Once your satisfied that yes there are two copies then you could safely remove one.
Nov 07, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Cant find ip address on ps3
If you are directly wired to your modem (not router), you will have to reboot your modem each time you switch between computer and console. When the modem boots up, it leases an IP address to the MAC Address of the connected device. Each device has a unique MAC Address. If the MAC Address does not match to the one it leased an IP to, it won't allow access to the internet.
You can get past this by "cloning" the MAC Address of your computer to your console.
To get the MAC Address (Physical Address) of your computer:
XP: Open the start menu, click "run" and type "cmd" then hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Vista: Open the start menu, in the search bar type in "cmd" and hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Now get into the network configurations on your console, look for an option of MAC Address cloning. Input the MAC Address of your computer, save and reboot.
Hope this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Mac mini display problem
Sounds like your monitor is not set right. Is the monitor LCD or CRT type? You can open system preferences from the top of the screen under the apple icon. Try and see if you can adjust the resolution settings. Also if you have an LCD screen set to "auto" adjust to reset the screen. Good Luck.
Aug 03, 2009 | Apple MB464LL/A Mac mini Desktop
Mini memorex traveldrive 1GB
To make any Drive Work formatting is a necessary step. If you don’t do it then it will never work.
Dec 19, 2017 | Memorex Mega TravelDrive 4 GB USB Hard...
I had a powerpoint presentation due I went to print it out and I removed my USB (Properly). When I went to class to give my presentation and my whole docuements folder was gone. Usually when my USB uploads...
You can try downloading other software to restore deleted files on your usb drive, you can also check if you saved the files on your computer.
You can also search google for free software you can try, you can type HOW TO RESTORE DELETED FILES ON YOUR USB
Mar 06, 2008 | Computers & Internet
Sync music from my Mac to my Juke phone
Mac JUKE Solution ,I have 416 songs on my JUKE and here is how I did it. Plug your JUKE into your Mac ,turn it on , go to music on your JUKE ,scroll to <sync music> close your JUKE. Look on your desk top for <TELACHIPS> go to Applications then Utilities then Disc Utility. Open Disk Utility click on the <1.9 GB Samsung Drive Icon> select <partition> under format select <Mac OS extended Journaled> run the program . Now you have a Mac Drive an can drop and drag iTunes into the <music. folder inside the TELACHIPS icon . If you have bought music from iTunes DON'T put it on your JUKE it is locked and will screw things up! there are ways to unlock them, It's all on the Internet
Nov 16, 2007 | Nokia 1100
PNY Verto GeForce 6800GT, (256 MB) PCI Express Graphic Card Logo
47 people viewed this question
Top PNY Computers & Internet Experts
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
