Question about Sony SDM-HS75 17" LCD Monitor
Sony SDM-HS75 tft lcd monitor
The monitor, when plugged in goes dark, after about 30 seconds. I can turn it off and then on only to have it be normal brightness for 5 seconds then dark again. At first I thought it was completely turning off but I can barely make out my background now, so it is on; there is just no illumination of the picture, please help.
    Problem Solver:
  • 6 Answers
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Posted on Apr 18, 2008
2 Suggested Answers
SOURCE: Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
Posted on Aug 15, 2009
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Screens goes dark after 3 seconds
Your power supply probably has a blow electrolytic cap on it.
You need to pull the power supply board out and have someone replace the electrolytic caps on it. Believe me....if the one for the brightness is bad...they are all suspect!
Caps are cheap...but knowing how to open the monitor and do the soldering is the part that takes some skill and may be costly.
Good luck and be careful.
Mar 10, 2010 | ViewSonic VX1935wm LCD Monitor
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
Monitor won't stay on.
hi there your problem .your monuter backlights gone so u need to new backlight
Feb 25, 2009 | HP w1907 LCD Monitor
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Scceen flickers on and off
You'll have to describe the problem in a bit more detail, because it could be a couple different things based on when it goes dark and what "dark" means.
I'm going to guess that the monitor is turning itself off after that second, but you might be describing that it doesn't say it's off, but there is no image (or maybe a really faint image that you can see in the bright light). Try checking it in the bright light after it goes dark. Also, does it seem different if you bang on, shake, or turn it upside down. Don't do this if you haven't already as it will more likely damage it than fix it, but if you have already banged on it, does it change?
I'm working on the same model with a similar problem (not sure it's the same) and will be ripping into it soon and will post the results.
Nov 02, 2007 | Liquid Video A170E101 Monitor
Sony SDM-HS75 17" LCD Monitor Logo
574 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
