Question about Canon PIXMA iP4000R InkJet Printer
Error code 5100
If I want to print, I hear that the printer starts, but then stops. The block with the cartridges does not move anymore
  • logcabin Mar 02, 2008
    Yes, please, I hope somebody out there will be able to help me.
    Thank you allready for trying.
  • 4,041 Answers
Hi You can Try
Canons faults
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Feb 01, 2010
Erreur 5100
Error 5100 is a print head homing error.
Check to see that there is nothing blocking the carriage from moving fully - a torn piece of paper, scrap plastic from an ink cartridge etc...
Also confirm that the ink cartridges are completely and correctly seated.
It would also help to know which model printer you are referring to.
Feb 27, 2011 | Canon Office Equipment & Supplies
The printer shows error code 5100 I think it has
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Solution 2:
Good Luck.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
I have a cannon printer mp160. I'm trying to print a document but I keep getting a service error 5100 message
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
5100 ERROR
As per the manual...
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Cannon printer mp460error code 5100
Service Error 5100 is Displayed
Cause
Action
Nov 05, 2008 | Office Equipment & Supplies
Error 5100
Cause
Action
Sep 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA iP4000R InkJet Printer Logo
63 people viewed this question
old marine
old marine
