Question about Blaupunkt Seattle MP74 CD Player
Blaupunkt MP74 no sound
I have connected the head unit as I believe to be correct from following the very vague intructions on Blaupunkt.com but now no sound. The power comes on as it should but no speaker sound. It is installed in a 1998 Ford Explorer. Any ideas? I have re-installed the OEM unit and it works fine. ???
  • Anonymous Mar 27, 2014
    Witch button must i press
  • 40 Answers
MGBGT- This is a fairly common problem,you ford has a built in amplifier,there is a wire that needs to be hooked up.If you used an after market adaptor,this wire should be marked and needs to be hooked to the remote turn on lead of the deck.Let me know if you need help. cooltek Mar,4/08
Posted on Mar 04, 2008
Can i find wiring harness for blaupunkt model chicago IVDB-7002
https://www.amazon.com/Blaupunkt-Harness-Power-Stereo-16-pin/dp/B0095OHU4Q. Contact seller to confirm that this is correct for the chicago. I believe it is.
Jul 20, 2016 | Blaupunkt Car Audio & Video
Can you provide me the code for BLAUPUNKT IDC A-09 BP915034455060 7 607 769 150 prod NR fiat : 735 273 184
CODE 5731
Code Entry as Follows:
If Required, Enter Code in Head Unit First.
Press And Hold " CD.C" Button
The Display Shows "CD Player" Then "0000"
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Tuning Up Button " ^ " To Enter
Nov 25, 2014 | Blaupunkt IDC-A09 5 Disc In-Dash CD...
Blaupunkt Laguna CD35
No! What speakers have you bought?
May 23, 2017 | Blaupunkt LAGUNA CD35 AM/FM/CD RECEIVER
I am getting "cd error" when put my disc into
  • Unfortunately it may be time for a new deck (stacker). You can try pulling the deck head out and removing the power for 10 minutes or so and re-connecting the power and this sometimes will buy you some time. Now a while back Blaupunkt was offering a free replacement for some of these units so it might be worth contacting the Blaupunkt web page for your country (where ever that be) http://www.blaupunkt.de/index.php?id=537&L=1 and see if the are still honoring warranties on them. In the end it may very well be time to replace your unit. This is a very common problem for Blaupunkt.
Regards, Tony
May 11, 2011 | Blaupunkt Car Audio & Video
I need help setting up my computer with my printer
Your request is somewhat vague but most printers can be installed by 1st: Using the software can came with the printer onto your pc. 2nd: Power off your pc and connect your printer using the paralle cable or the usb cable. 3rd: power your pc and printer on and follow on screen intructions (if any)
Good Luck
C2Solutions, Inc.
Nov 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to tune in stations on blaupunkt siena rcm 148
Thats an amplifier, not a head unit. The point of that is to power the speakers. The output on the head unit plugs into this, and the speakers plug into this. You tune the station on the head unit in the dashboard
Oct 08, 2009 | Blaupunkt THA125PNP 300 watts RMS x 1 at 2...
Chicago IVDM 7002 and DX-V connection? I have installed the head unit, tuner and DX-V into my car. All apears to work ok but the remote for the DX-V does not opperate. I have swapped all components as I...
I am sure you must have followed the manual (http://www.google.co.in/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.blaupunkt.com%2Fus%2Fdownload%2FInstall_IVDM7002.pdf&ei=9Gl8SqvsDsz-kAW6v6DqAg&usg=AFQjCNE0l78Mhn5aCMBLgKvIiDL1kzLZZA&sig2=NutBRfrwRxktHq4yMQ6Ycw : is where I downloaded the user installation guide and some aspects while reading it & your description/procedure rang a bell while going thru the precautions mentioned therein, and are:--
DO NOT connect any speaker wires to the metal body or chassis of the vehicle.
• DO NOT connect the speaker common (-) wires to each other.
• Connect each speaker wire directly to each speaker terminal.
• All speaker common (-) wires must remain floating. ie - no common connections or connection to vehicle ground.
• Connect each pair of speaker leads only to a single speaker (or speaker system) that has an impedance of at least 4 ohms, as well as a 50-watt power-handling capability.
• DO NOT connect speaker leads to any inputs on external amplifiers. This will cause damage to the internal amplifier of this unit.
Somewhere here there is note which is jarring my sixth sense. Hope you will be able to catch the drift and find out where you went wrong....................................sodeep
Aug 07, 2009 | Blaupunkt Car Audio & Video
Blaupunkt IDC A09
Hi, do you have the IDC A09 PSA or just the IDC A09?
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Blaupunkt Seattle MP74 CD Player Logo
212 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
