Question about Mitsubishi WS-65908 TV
Power went out, tv won't come on
There is a blinking light on front (timer) Remote will not work, or can't turn it on with power button. The tv was off when we had a power outage.
  • 1 more comment
  • cowboyfanatk Aug 23, 2008
    Power on 65" big screen went out, and wont turn back on. No outages..Doesnt blink at all, but light comes on for split second then turns off right away. I unplugged tv, and plugged back in. No fix.. i opened back panel, and checked a close by clear fuse. Seems to be fine. No black marks, or signs of it being blowned. pulled power source plug from circuit board, and plugged back in. Then plugged tv back in and turned on, but still no fix..I can hear a clicking nose going on and off, when i try to power on the tv. It comes from about the middle of the board close to two brownish red cylinders.. Can you help me out here? Thanks,,
    Frankie
  • mikelca Sep 24, 2008
    I have the same problem. After a very bried power outage my tv now has a blinking green light and it will not turn on. How much should a reasonable repair shop charge to fix this tv?
  • Anonymous Mar 16, 2014
    Problem originally started when the remote quite functionong. Then the front panel buttons except the power button quit functioning along with I am only able to use the antenna input. Is there a simple fix, or is this great TV ready for the trash heap?
    Scholar:
  • 52 Answers
If you are lucky, it's only a blown fuse, but with a blinking light on the front, this is doubtful. I would pull the back cover anyway and check the fuse. If fuse is ok, then normally if you have no sound and no picture, you have a blown "horizontal output transistor". Look for the big wire (usually red) coming from the picture tube to the circuit board. The red wire goes to a large object on the circuit board called the "flyback" transformer". Usually very near this transformer you will find the h.o.t. (horizontal output transistor). It will normally be mounted on a silver piece of metal (a heat sink), about 2 or 3 inches square or possibly rectangular. The transistor has three pins coming out of it and is probably the largest transistor you will see that has only 3 pins. The upper portion of the transistor will be clamped (or screwed) into the metal heat sink. You have to desolder the h.o.t. and replace it with a new one. The h.o.t. usually costs only about $10.00. If the fuse and h.o.t. are good, then the "flyback" is probably bad and they run from $25 to $100. If the TV is worth only about $200, then replacing the flyback is not recommended, because there is no guarantee that this will solve the problem. Keever.
Posted on Mar 02, 2008
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
While watching tv I touch something on the remote to make the tv go into "on timer" The red light is blinking. I have removed power then on again the remote and tv controls work but after 4...
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
Jan 04, 2011 | JVC AV-27920 27" TV
My jvc telivision wen i plug in the tv it comes on and then cuts off i have no remote for it the remote is not working but there is ah light that comes on the tv next to the power button it says timer and...
The television is lock in timer mode. are there any buttons on the front panel where you can get into the menu. If, so go where it says timer and turn it off and see if that helps you.
Jul 14, 2010 | JVC RM-C18G-1H Remote Control
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-65908 TV Logo
1,490 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
