Question about GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE RUNS BUT DOES NOT HEAT
IT'S A GE SPACEMAKER XL1400
  • 11 more comments
  • jon_123 Mar 02, 2008
    Are you indicating that the clock, fan and panel would still work-- but the microwave would not heat-- if the fuse was blown? Should I check the fuse?
    Thanks.
    Jon
  • jon_123 Mar 03, 2008
    My son just hit the accept button by mistake. I still don't have a clues about what's wrong with the microwave. How can I continue to get help???
    The fuse, which is in the top area behind the vent, is good
    You have any idea what's wrong with it. I'm pretty good with electronics... Take it to Best Buy????
    MICROWAVE RUNS BUT DOES NOT HEAT.
  • jon_123 Mar 04, 2008
    You're right. I found this number inside JVM1450WA001....
    I tested all fuses including the thermal fuses, the button shaped with a wire on each side. One of them did not have continuity (did no measure short) and I ordered it yesterday. It's the one that says 40/70 in the back part.
    You think this could be the problem.
    Thanks for your help.
    Bobbyj,
  • jon_123 Mar 10, 2008
    Hey, great timing. I got the part this morning, replaced it, but it not heating.... The thermal fuse I ordered is part# WB27X10194; this one was NOT near the Magnotron: it was in the compartment behind the keypad panel. The one next to the Magnotron was good.
    When I turn it on, I hear a sound like sparks. How can I determine if it's the magnotron?
    A decent microwave in my area is going for 250, so I'm going to have to fix this one.
    Before I order the Magnatron, I have one question: Does the sparking sound mean the magnatron is bad?
    I will order it tomorrow and let you know how it turns out.
    Thanks.
    Sergeant:
  • 395 Answers
Remove power from the unit back the cover off the unit above the magnotron is a button shaped thing with two wires on either side of it. there is another one above the heat box. measure them with an ohm meter. these are thermal fuses they should measure short if open replace them. if short replace the magnotron. the magnotron is a high voltage device so arch it first to discharge any stray voltage.
common problems to microwaves are:
door switches; make sure they open and close the circuit properly use the meter to check.
fuses (thermal and circuit); make sure they are good use a meter.
High voltage to the magnotron; you need a high voltage probe for this ( same type used in tv repair). make sure you are getting at least 20kv if not replace the high voltage board.
the magnotron; common failure.
Posted on Mar 03, 2008
  • 4 more comments
  • Robert Johnson Mar 03, 2008
    also, the model # you give is a series of microwaves the real model # should be on the inside of the door or side of the door. post that so I can give you part #s
  • Robert Johnson Mar 04, 2008
    more than likely that is the problem. if it should open again then the problem is the magnatron is over heating and needs to be replaced.
  • Robert Johnson Mar 10, 2008
    how have you made out so far?
    sparking sounds are internal arching from the magnatron replace the magnatron part # WB27X10017
    yes arching is from the magnatron it's bad
  • Robert Johnson Mar 22, 2008
    how have you made out with your repair?
    Master:
  • 788 Answers
Did you inspect the board for burnt components or cracked traces or solder joints?
Also suspect the magnetron, might be easily replaced.
Otherwise, new ovens are getting fairly cheap, I recently bought a Panasonic unit at Walmart for $80 CAD and it's a 1.1 cubic feet 1000W oven, works awesome.
Look here: http://www.gallawa.com/microtech/data1a.html
This guide here mentions testing the diodes in the high voltage transformer: http://www.partselect.com/microwave+test-diode+repair.htm
  • 2,336 Answers
Check this SITE for troubleshooting the transformer and magnetron. The magnetron fail very often on microwaves, that is the device that heats up the food.
    Sergeant:
    Champion:
  • 281 Answers
Take it to best buy
  • 790 Answers
HELLO!!
Usually if the internal fuse had blown, the microwave part would stop working all together.
Posted on Mar 02, 2008
Ge spacemaker microwave xl1400 works but does not heat
Pledase check the operation of the door safety interlock system. If you routinely open the door while the oven is operating, these small switches will eventually burn out and not work.
Oct 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
May 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
WONT HEAT
I AM LOOKING FOR A SOLUTION I DON'T HAVE ONE
Dec 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
96 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
