Question about RCA E13320 13" TV
Crooked screen screen is tilted a little...opened up , was going to turn yoke but seems to be glued in place. would this straighten the screen or is there an adjustment?
  • 30 Answers
No adjustments only the yoke. You might be out of luck if glued
Posted on Aug 03, 2008
How do i fix a crooked screen on an older tube t.v.?
The yoke needs to be turned slightly and the picture will move in the same direction as you rotate the Yoke. (located on the neck of the Picture Tube) Just loosen the screw on the yokes clamp slightly then carefully touch only plastic edge of the yoke and turn it slightly while an assistance watches the picture be careful not to slide the yoke up hugher or lower on the neck. It has to saty at the same spot but just rotated slightly.The pic below shows the yoke with yellow arraows. Do not disturb the purity rings (RED ARROW) or it will cause blotches in the picture so its very important not to disturb the item with red arrow.
Mar 06, 2013 | Televison & Video
Cant remove screen seems glued on hp pavillion dv5 1007
ummm, i'd doubt that it is glued unless you had the screen repair previously by a shoddy repair shop. First of all normally the screens are held in place by screws that are hidden by little rubber bumper covers or some type of covering on the plastic that is around the screen. Use a safety pin or small flat head screwdriver to remove the covers and expose the screws. Then use a phillips head screw driver to remove the screws. Once all the screws are removed use your fingers to slide along the inside of the plastic around the screen and pry it loose from the screen.
Mar 10, 2012 | Computers & Internet
TV
the slugs have nothing to do with tilt; unless a tilt setting in main menu bonded yoke has no adjustments for this issue.
Mar 07, 2012 | Televison & Video
I have had RedHead 7x - 21x binoculars for about 4 years now and I have ran into a problem. When I look through them I am seeing double. I have adjusted the focus and changed the distance that I am holding...
You have the classic signs of the most common binocular fault: a bent or broken eyepiece carrier yoke.
The cause is usually due to the binos being dropped or stored standing on the eyepieces. The only cure is a replacement yoke, but the repair is rarely cost-effective unless the binos are really expensive and top-quality models. Although most RedHead models aren't cheap, they certainly don't fall into the realistically repairable bracket.
Broken/bent yokes cannot be repaired: If bent, then it's near-impossible to unbend them accurately enough and in any case the process will always either break the yoke or will severely weaken it. Broken yokes cannot be glued together as the contact point is just too tiny for the loads it carries, and as it usually bends before breaking you'd simply end up with a bent yoke afterwards even if you could glue them.
Sep 11, 2010 | Optics
Double vision
The yoke which connects the eyepieces and keeps them aligned as the focus changes is damaged. If you can easily move one eyepiece back and forth with respect to the other then the yoke has broken, if not then it's bent, probably cracked and waiting to break.This is easily the most common fault on most binoculars, and it's always uneconomic to repair on budget brands such as Bushnell.
If bent, the yoke *might* be able to be straightened, but it will be weakened and the alignment afterwards will rarely be spot-on. If broken, then the yoke must be replaced professionally but the repair will cost more than replacing the binoculars with new. In any case, it's unlikely that Bushnell even list the spare part for it. The break cannot be simply glued: the contact area is too small to carry the loads it has to carry, and you also usually find that the yoke bent before breaking anyway so you then have all the same problems as you do with a bent yoke.
The fragile nature of the yoke is why binoculars must always be inserted into their case with the objective lenses facing down; this avoids shock loads on the delicate yoke assembly.
I hope that you've found my posting to be of use and in return ask only that you take a moment to rate my answer.
Feb 07, 2010 | Bushnell Optics
Picture is slightly tilted
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Nov 20, 2009 | JVC AV-32FA54 32" TV
Sony 32 inch crt tv
On the neck of the picture tube you will see the large yoke. Loosen the srew slightly and just rotate the yoke assembly very little counterclockwise. That should correct your problem.
Oct 12, 2008 | Televison & Video
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Mar 08, 2008 | InFocus Proxima DP6155 Multimedia...
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
WEGA KV-34HS420 34" TV
If you have coloured patches down the sides of the screen they are normally caused by one of three things.
1,strong magnet fields close to the t.v. e.g.hifi loudspeakers.The cure would be to move the speakers away from t.v. Switch t.v. off for up to forty mins at the switch and then try again.
2,failure of deguase circuit inside t.v. a job for an engineer/tech do not go poking about inside tv's if you do not know what you are doing,very very dangerous.
3,sony t.v.'s do get problems with their scan yokes sliding down the neck of the tube,they are wedged and glued into place,the glue gives and the yoke can move.Again this is a job for an engineer /tech.
Oct 31, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
RCA E13320 13" TV Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
