Question about Kirby Ultimate G Bagged Upright Vacuum
How to replace allergen filter?
Can you provide instructions on where and how do you replace the allergen filter?
    President:
  • 1,673 Answers
There is no filter, they are talking about (hepa)Ultimate G vacuum bags.
Posted on Mar 02, 2008
What is the main difference between the basic dyson v6 and v8 vacuum?
Hello, this is Ava with Think Crucial.
The main difference between the V6 and V8 Dyson models is the mprovements in power and run time of the unit. The Dyson V6 has the V6 motor that pumps out 24 air watts in normal mode. In max mode that number goes up to 100 air watts. While the Dyson V8 comes equipped with the latest V8 digital motor that produces almost 20% more power than the V6 motor. It has the same 2-tier radial cyclones that capture fine dust and allergens. A post-motor HEPA filter keeps those allergens inside the bin. There is also the Bin improvement as Dyson was able to increase the capacity to 0.14 gallons for Dyson V8. This is around 0.03 gallons bigger than the V6.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 22, 2016 | Dyson Vacuums
How to open lower filter on dyson dc19
Hi there, it's Jack at Dyson.
DC19 has two filters, both engineered to last for the lifetime of the vacuum in normal use. The pre-filter should be washed at least once every 3-6 months using cold water without detergent, as shown in the video below. Allowed at least 12 hours for the filter to dry completely before replacing it.
The post-filter located underneath the clear bin is engineered to capture microscopic allergens, and carbon from the motor. It does not need any maintenance - in fact, attempting to wash or clean the post-filter could cause damage to the vacuum not covered under guarantee. For this reason we advise against accessing or removing the post-filter.
I hope this helps, but if you have any questions about the filter, or regarding the performance of your DC19, please get in touch with our experts directly so we can provide further assistance. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson Dc19db Multi Floor Cylinder Vacuum...
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
The belt is broken on our Hoover Allergen Filtration Model U5018-900 120 v. 60 Hz 12.0 A. Belt 38528040. Where can I get the belt and instructions on how to replace the broken belt?
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
http://www.hoover.com/product.aspx?model=U5018900&ds=false
Instructions for replacing the belt are on page 9.
You can order the belt here:
http://www.hoover.com/shop/searchresults.aspx?itemid=221224
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Oct 07, 2010 | Hoover U5018-900 Bagged Upright Vacuum
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Changing the HEPA filter on a DC17 Animal
Just took my Dyson in and yes my HEPA needed changing. It's under the right wheel (as you're looking at the machine); you can see it through the "vents" above the wheel. The screw is on the bottom of machine.
You will probably need a Torx (star) 15 screwdriver -- that's what Dyson seems to use everywhere.
Feb 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Dec 30, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Hoover Vacuum Elite (Allergen Filtration) 12 Amp Motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=646648
Generic problem for all Vacuums
Hoover Vacuum Elite (Allergen Filtration) 12 Amps...
Posted by Maya B on Jun 04, 2008
I received this vacuum (Hoover Vacuum Elite/Allergen Filtration 12 Amp Motor) from a friend. After using it in a few rooms it started giving off this burnt odor and the motor starts to sound as if it's dying. What is wrong with it and how can I fix it? If I need to change a part, which one is it and where do I get it from?
I love the suction in this vacuum even though it can be very loud when the attachments are being used. You can email me at fine_wonder@yahoo.com Thanks very much! -Maya
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Vacuum Elite/Allergen Filtration 12 Amp Motor. It certainly sounds like a motor that is on its way to going out or burning out – you can replace the motor and you can get the part from your local vacuum cleaner dealer in your area, either new or used to save money, or you can contact the cust serv dept @ Hoover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
43 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
