Back to:
Tags:
Magic Chef CER3740 Electric Kitchen Range
F3 fault code in oven mode--problem with oven...
posted by xbikeman2 on Mar 02, 2008
where is sensor located--cannot find schematic diagram for sensor location
Comment by xbikeman2, posted on Mar 02, 2008
I found it to the left of the door just below the upper element. I actually didn't have the patience to wait for your answer. I found it by following the wiring diagram. But if I had been patient, your answer would have been perfect.
Thankyou.....xbikeman2
Comment by xbikeman2, posted on Mar 04, 2008
to tech 17: Thanks for the info. The wires entering the sensor were burnt off at the sensor. But if it happens again, I'll know what to look for. Thanks again--xbikeman2
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
tech17
Rank:Guru Guru
Rating: 88%, 1063 votes
open the door and look in side in the left or right corner you will see a brass rod thats the sensor
Comment by tech17, posted on Mar 02, 2008
im here if you need any more help try cleaning all the connectors to the clock or eoc before replacing it and if there a mylar ribbon going to the clock reply and ill tell you how to clean that if you can use a meter you can test the sensor before replacing it as the code isn't absolute like if there is resistance between the connectors and the probe the fault code will say bad because it cant communicate see so it says bad probe
Rating Locked! (?) xbikeman2 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on f3 fault code in oven mode--problem with oven temperature sensor:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
everytime I push bake or broil the lock light comes on the...
The timer has been going off for no reason and very...
I have an magic chef stove that started to beep f2 the...
Can I get a replacement top for my Magic Chef range that...
One of four stove top coils (left rear coil) does not heat...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
