SOURCE: washer pauses itself
My name is joyce
Are you using He deturgent?
If not this is the problem.
to remove the suds from the pump now you will have to put one tsp of oil in where you put powders at and run cycle on normal and then see what you get. if this dont work let me know and we will go from their.
thanks,
joyce
SOURCE: Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
SOURCE: GE Front Load washer keeps pausing and have to
Try to clean the discharge pump filter first (Instructions in the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min http://www.fixya.com/support/t8933273-general_electirc_washer_model
Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
