Question about Acer Aspire™ T180 PC Desktop
No sound coming from monitor when sound icon indicates up high
  • 1 more comment
  • pegdean Aug 12, 2008
    no sound from external speakers or monitor speakers. All volume controls up high and no mute is on anywhere I could find. The external speakers worked when I first set up the PC and just stopped working without me changing anything. Device driver check says it is working......
  • bandara Aug 12, 2008
    how to setup speekers & headphone
  • Anonymous Feb 01, 2009
    sound not working
  • 3 Answers
Check audio cable connected correctly, then check the monitor menu for sound settings are correct. If that all seems OK, plug in some external speakers to check if soundcard is functioning.
Posted on Mar 02, 2008
I want to hook my xbox to a Dell? ST2010B with an HDMI. I was wondering if there is a way to get sound? The xbox displays but I get no sound.
My research indicates that that the Dell ST2010B monitor is equipped with a sound source, but there is an optional 'sound bar' that is or was available for it. see
does 20 Dell ST2010 Black High Definition Monitor have built in speakers
and
ST2010 Monitor Has No Sound
8.March.2015
Dec 26, 2010 | Dell 1800FP Monitor
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
High pitch sound coming from my old LG 700E monitor
High pitch sound maybe an indicator of a defective monitor or a wrong or incompatible resolution setting of your display properties. The usual is that you have set the resolution higher than that the monitor can hold. Boot the pc in a safe mode. This will give you an option to set the resolution to that resolution accepted by your monitor, the usual is 1024 x 600 or so, avoid higher resolution than this.
Sep 13, 2010 | Computers & Internet
Have installed a new monitor and cannot get any sound
Hi.
Silly Question. Moitor does have speakers, it has happened in the past!
Ok! you have speackers. Go to control panel click sound icon (Speaker).
Tab sound, choose exit to test, click square button you should hear sound, remembering too insert jack plug in the correct hole rear of your poota(Usually GREEN)
Nov 12, 2009 | Computers & Internet
Monitor flashes on and off
When it comes back from BLACK is it like a Power ON with the display intensity coming up gradually, OR does it POP back with an INSTANT ON - like appearance.
Slow appearance would indicate basic Power loss to the Monitor, or failure of the internal Low Voltage inside the Monitor's Power Supply.
Instant OFF/ON would indicate either:
1. Loss/regain of Video Signal
2. High Voltage Loss/Regain within the Monitor. This would be accompanied by a 'crackly' high voltage 'staticy' sound.
So, what's the further story???
Aug 12, 2009 | HP w19 19" LCD Monitor
No sound coming through speakers from microphone
ok i have windows vista so u have to right click on sound icon speaker then click playback n select conexant high definition smartaudio 221 n right click it as default n u gotta re load up acid then right click n insert audio
Dec 14, 2008 | Sony Acid Music Studio 7 Full Version for...
Sound indicator
you can find it in control panel option.do this-
  1. click on start button on task bar
  2. click on settings option
  3. click on control panel option
  4. in control panel click on (sounds and audio devices) option.
  5. and click on place volume icon in the task bar.thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 24, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Acer Aspire™ T180 PC Desktop Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
