1992 Hyundai Sonata Logo
Posted on Feb 26, 2010
MSD for Hyundai Sonata GLS 1992 16V DOHC
Hi;I live in Iran and I have a Hyundai Sonata GLS 1992 4cyls 1997cc 16V DOHC(G4CP Engine type) and I want to install an MSD(Multi Spark Discharge) device.Please guide me if it is possible or not.And how can buy it and which model?My relatives live in USA and they can buy it and send for me but they do not know where they can buy it and which model? My E-Mail: [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
627
Points
Hi;I live in Iran and I have a Hyundai Sonata GLS 1993 4cyls 1997cc 16V DOHC(G4CP Engine type) and I want to install an ecu 39110-33150 for care
1helpful
What is the power of engine hyundai sonata sedan 2007
Hyundai Sonata 2007 have the two variants which are Sonata GLS and Sonata SE. So check out the engine power of the Hyundai Sonata, which are as follows,
=> The Sonata GLS is powered by a 2.4-liter 4-cylinder engine that makes 162-hp and 164 lb.-ft of torque at 4,250 rpm.
=> The Sonata SE and Limited are powered by a 3.3-liter V6 engine that pumps out 234-hp and 226 lb.-ft of torque at 3,500 rpm.
Changing tensioner pulley for 2011 Hyundai Sonata
This is a link to a youtube video. Not same year as yours. Thinking is removal method would be the same. Timing chain replacement Hyundai Sonata 2006 2009 GLS 2 4L DOHC Install...
Hi I would like to kw if a hyundai elantra j1 1994 model starter is the same like a hyundai sonata 1995 starter
Hi Warren, I had a 1995 Elantra and they were very good at reusing their tehnology on all their models. What engine size are you talking about here. Mine was 1600 GLS but there was a 1800 GLS as well. On the Sonata some had bigger engines which may have required stronger starter motors, so please check first.
1helpful
HI, I have a 1997 Hyundai Sonata 2.0 GLS. I need a diagram to show me how to replace the vacuum hoses from the inlet manifold right through to the thrmo switch on the block. The Mech who was working on the...
That you're going to have to get from the dealers parts dept. They should be able to photo copy the diagram for you. Even service manuals lack a full vac diagram, they usually show only basic emission diagram because that's a fed. mandate.
7helpful
Picture of firing order for a 2000 hyundai sonata
2000 Hyundai Sonata 2.4 liter DOHC L4
2000 Hyundai Sonata GLS 2.5 liter SOHC V-6
Hope this help (remember comment and rated this).
Trying to replace serpintine belt but air conditioner pulley seems to sit lower than it does on diagram
I do not know what Diagram you are referring to. Also I am not sure if you have the Sonata with the 2.4L DOHC In-Line 4, or the Sonata GLS with the 2.5 SOHC V6.
In any case:
Click on the following Free-Direct Link. It has the Serpentine Belt Diagrams. Compare these with your Vehicle and/or Diagrams you have.
http://www.2carpros.com/car_repair_information/year/2000/make/hyundai/model/sonata/2000_hyundai_sonata_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
2helpful
Trouble replacing timing belt ... setting timing need to know how to line up the marks on the camshaft pulleys with the camshaft and balance shaft .. 1996 hyundai sonata GLS 2.0l DOHC .. gasoline engine
Sorry for the severe delay.
I am personally going back to answer your unanswered question.
I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Timing Belt Diagrams with Marks for the Camshaft and Crankshaft that you will need. It also has numerous other helpful diagrams for use.
Again my apologies...
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1996/make/hyundai/model/sonata/1996_hyundai_sonata_timing_belt_diagram_marks.htm
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
