Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv screen i pressed somewhere on the sky remote, and now AV1 shows all the time on the top right of the tv screen
  • 325 Answers
Using your SONY tv remote... look on the remote and you will see a button with a little i sign on it press it. this should disappear
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Televison & Video
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
To suppress the AV1 symbol on screen
on original sony remote press the DISPLAY button once
Mar 26, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
