Question about Vacuums
Brush Repair Question
I have owned my Hoover for 8 years. The brush has been replaced several times and the one I have now is in good condition. I also replace the belt routinely and have a brand new one now. However, the vacuum is very loud and creates a terrible smell when I run it. I believe this is because over time the slot where the brush goes in has been stipped, and it just keeps getting worse.
Is this even worth taking in for repair? I don't see any removable part that can be replaced to fix the problem. Is 8 years a good life for this vacuum, or should I expect more?
  • smoner4 Mar 03, 2008
    Here's the thing - the brush sits directly in the base of the vacuum. I don't see any removable tray.
    Thank you so much for the advice.
    President:
  • 1,673 Answers
Could be that is the case if it is a plastic smell, and the brush roll is loud when turning. Depending on which model you have, either have to replace the nozzle or if the brush roll sits in a removeable tray, you can replace it. If you take it in for service, it will probably run $80+ parts and labor.
Posted on Mar 02, 2008
Hoover F5915-900 brushes will not rotate
The motor rotates the bar. My guess would be that the rubber belt that goes from the motor to the belt has fallen off the bar , broke, or the bar is not seated properly. GOOD LUCK FRIEND.
Nov 13, 2014 | Vacuums
Hoover 8+spin1600 forever banging when spinning16
Hi! If your unit is noisy while the brushes are spinning this can mean that your brushes are worn or damaged. Try removing the brushes by pushing the two brush release buttons at the same time. Turn the cleaner on and see if the noise persists. If the noise stops with the brushes removed, you will need to replace your brushes. I have included a link below where you may go to purchase a replacement brush roll if needed. Hope this helps!
Search Results
Oct 02, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Off and on brush want work
Start by replacing the belts. They should be replaced at least twice per year for proper cleaning. The flat belt will stretch and lose elasticity and the "v" belt wears on the inside grooves. If the smaller narrow inside part of the belt is less than 1/8" it has worn and needs replaced.
Dec 05, 2013 | Hoover Vacuums
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover Widepath Tempo - belt slips off when we start it. Can you help?
Perhaps the belt is stretched. Replace it with Hoover belt # 38528-033. Remove the rug plate on the bottom ( 4 screws ), and remove the brushroll. Place the belt around the motor shaft first, then position it around the brush, and push the brush back into the housing. Expect resistance from the belt, as it must be stretched several inches. After the brush is in place, turn it with your fingers to be sure the belt is centered, and not pinched between the brush and the housing. After replacing the bottom plate the vacuum should be ready to use.
Feb 18, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Hoover Vacuum correction
I don't know what is your experience with wire's soldering, but you should remove the insulation from the damaged wire and solder the disconnected edges. Then wrap an insulation band on the repaired wire first and then on all the other wires. Be aware power cable is disconnected !!!! If you can't do it by yourself - repair cost for it should be very cheap. Good luck !!
Jun 28, 2006 | Hoover S3614 Vacuum
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Vacuums Logo
60 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
