Question about GE Profile JTP18 Electric Single Oven
GE Profile F7 Error Code
I have gotten the F7 Error Code. I can use the oven for a short amount of time and then the error code comes up. I can turn off the power to the unit and it resets only to happen again. Please, any suggestions
  • 4 more comments
  • robbie39 May 04, 2008
    i am geting an f7 error code on my wall oven. I want to know how to stop the annoying beeping?
  • nhraim Jun 08, 2008
    same stupid beeping... and F7.. pleaelpse h
  • Anonymous Jun 22, 2008
    f7 and EA are flashing on my oven. My oven won't work? We've ahd it only 2 years? help!!! - Oven less in San Diego
  • jjarmenta916 Nov 18, 2008
    keep getting f7 error code. oven shuts offs. how can i fix this?
  • cdiakun Nov 28, 2008
    I also have the same problem with the F7 flashing, but at times I have cannot use any of the buttons on the oven. Nothing works, no matter what button you press. We tried turning off the breaker like it says in the manual and that helped for a while. We had someone come and look at it and when we turned the breaker back on everything miraculously was working. I was charged $50 for a call out fee and then the next day nothing works again. We have been told this would be $500 and $750 to replace the control panel. The oven is eight years old and to be honest is not used as much as most households. Any suggestions would be appreciated. Thank you.
  • Anonymous Jan 05, 2009
    We have a 5 year old GE Profile gas range and we get the same F7 Error code repeatedly. Lately, it occurs more frequently than before. We unplug the range for 5 minutes per the troubleshooting instructions in the manual, but it still does not respond correctly. In fact it appears only to respond after being unplugged overnight...But of course it doesn't last.. We are told the service call is $80, plus an expected repair/replacement cost of some $300-$400.
    It appears to occur mostly when we use the oven...Perhaps it's an electronic component that is sensitive to the oven's heat?
I'm not sure what your problem is, but I have the same one. My stainless steel glass top model ?? is beeping all the time with error f7 on all the 4 tem control readouts. I'm guessing this is your problem as well. By turning the temp knobs it will stop, but sometimes restarts later for no reason. Other sites mention a ribbon cable on the touch controls (if yours has it, mine does ) that must be cleaned with rubbing alcohol. You turn off the power, and after unlocking the cable you clean the contacts with an easer and a q-tip w/rubbing alcohol. I don't know if this works but I might try it as the beeping is driving me crazy! The service techs will try and sell you about $450 in parts to fix the problem. This problem apparently has plagued these units for almost 10 years. Seems heat makes the cable get shorts at the contacts.
I HAVE NOT TRIED THIS YET so beware, but I had a short in my microwave and the site helped me fix a $500 control board for about 15 cents ( jumped a short on the board with a small wire!) Hope you get your problem fixed.
Posted on Mar 13, 2008
Ge performance profile F7 error code
code f7 is a error code for self cleaning device
Aug 17, 2012 | Whirlpool RBS275PD Electric Single Oven
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
Ge profile convection oven giving error code F7. What parts do I need
Hi
Thanks for using FixYa. Error F7 means that the function pad button is stuck or the clock has gone bad. If you are unable to unstick the button then to resolve this issue you’ll have to replace the electronic range control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | GE Profile JTP18 Electric Single Oven
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Aug 17, 2008 | GE Profile JTP18 Electric Single Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
2,757 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
