Question about Mitsubishi VS-50605 50" Rear Projection Television
Whats a quick solution
On my t.v, the picture rolls with these horizontial lines. whereas you can't see the picture. sometime when I turn the television off an back on it stops
  • bean257 Mar 30, 2008
    I have the same problem with my Mitsubishi vs 50705 the pirture rolls then there are bars across the screen. THis use to disapper after a while or by turning off and on, but now it wont stop
    I am hesitate using service people as they think you dont know anything and try to take advantage
    Any suggestions?
  • Mitsubishi Master
  • 8,617 Answers
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Posted on Mar 02, 2008
WHEN I TURN ON TV I GET A RED SCREEN WITH HORIZONTIAL LINES STAYS ON FOR 10-15 SECONDS THEN TURNS OFF STAND BY LIGHT BLINKS 7 TIMES SORRY THIS IS A SONY KV35V65 TV
this is a red retras line problum
[1] red cathoud video amp. trangester is sort or dry canaction
[2] red cathoud is sorting with filament terminal is in side pictur tube
so pls. cont. your nr. tv. tech. solve this problum. it is not very expancive
* this is a coman problum if your tv set is 7 to 8 year old.
Nov 10, 2009 | Sony KV-32V65 TV
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
Horizontial lines and picture deteroration
This one is tough. Can be either the DM module, formatter board or optics block assy. Check for bad capacitors first in DM module, then signal board then formatter board. If your lucky, bad capacitors maybe what it is. If not, a new optics block is what you'll be needing.
Dec 20, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Toshiba 55H70 COLOR PROBLEMS
turn your red screen voltage down till you get grey, your convergence out puts will need replacing
also the limiting resistors usually a low resistance, cheers parts from global look for stk -*.*
Oct 08, 2008 | Toshiba 55H70 55" Rear Projection...
GE TV stopped showing picture. Made very loud noise which continued. Now bright white narrow light runs horizontially across screen
can you post a picture of what your screen looks like? Also can you post the model number of your set?
Apr 27, 2008 | Televison & Video
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Horizontial adjustment
your monitor has a problem with vertical sync. its time to bring your unit to a qualified service technician.
Jan 15, 2007 | RCA F36444 36" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
