Question about SanDisk Sansa e260 MP3 Player
I had my sansa e260 for 5mos now, but after i downloaded music last night, i turned it on and the screen was refreshing the database, like normal procedure, but half way into the refreshing the database it locks and the screen dissapears and i get several blue lines running down, i have tried to turn it off but i can't, so i let the battery run out and tried it again but still does the same, any other solutions
Soy osito
Posted on Mar 02, 2008
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Hang on refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh database
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh Database
I have the same problem and can not figure it out!!! how do I refresh database??!!!grrrrrr
Need help as well.
Thanks
Dec 12, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa Hack!!! please help!
You device is too full. You need minimum 6MB for the "music database". The more music you have, the bigger the database needs to be. Try freeing up 30MB or so, that should solve it. Please add to the question, dont select NOT HELPFUL if this didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Hack on Refreshing Database!!! HELP!!!
Lock your sansa and hold the rec button while starting it up.
It will go to recovery mode. Hook it up to your computer. Now download this file: "http://www.MegaShare.com/392319" put it onto the device that should pop up that is called "16MB-FORMAT". Once you put this file on there you should take out the thing that links your sansa to the computer and it should install the firmware. It will also restart your sansa. (Make sure that you unlock your sansa first.) And Now all problems should be fixed!
SanDisk Sansa e260 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
