Have you checked the power plan settings? This is usually accessed by a battery/plug icon on bottom right of the screeen, if not then on the control panel.
right click on the icon and select power options. This gives you options for balanced, high performance or power saver. Clicling on change settings allows you to set CPU performance for mains and battery for each power setting.
for instance I usually use the balanced setting with a fast CPU when using mains and slower (to conserve battery power ) on battery.
Dear your charger if faulty replace it or borrow from any friend (this problem is due to condenser which inside the adapter) for conformation if your lapi work properly then buy a charger
