Question about Whirlpool Duet GHW9150P Front Load Washer
Tar-like substance appearing on clothes and washine machine
Periodically, I find black, sticky tar-like substance on freshly washed clothes and inside our Whirlpool Duet washing machine (only four years old). Any idea what's causing this and to fix the problem?
  • Anonymous Mar 25, 2014
    Tried less soap and less clothes
    President:
  • 1,314 Answers
I havnt seen any flashes on this id look closley at what your putting in the washer as there is nothing in the unit its self as far as mfg that will cause this also try this 1. Open the washer door and remove any clothing or items from the washer.
2. Inspect the gray colored seal/bellow between the door opening and the basket
for stained areas. Pull back the seal/bellow to inspect areas under the seal/bellow.
3. If stained areas are found, wipe down these areas of the bellows using the following
procedure:
a) Mix a dilute solution of liquid chlorine bleach and water (3/4-cup bleach in
1 gallon of warm tap water).
b) Wipe the seal/bellow area with the dilute solution.
c) Let stand 5 minutes.
d) Wipe down area thoroughly with a dry cloth and let the washer interior air dry.
e) Please note:
- Do not use bleach at full strength for cleaning surfaces.
- The use of rubber gloves is recommended when cleaning for prolonged
periods.
4. To begin the clean out cycle, do the following:
a) Open the washer door and remove any clothing or items from the washer.
b) Be sure door is closed.
c) Open the dispenser drawer and remove the detergent divider from the main
wash detergent compartment. See the Use and Care Guide for instructions.
No additives will be added at this time. You will be required to add them at a
later step.
- For Whirlpool Duet, select the “Power” button.
- For Kenmore Elite HE products, move to the next step.
d) Select the “Normal” wash cycle.
e) Select the hottest wash water temperature available, (not all temperatures will
be available).
f) Select the highest spin speed available.
g) Select the additional or 2nd Rinse option (if available).
h) Press and hold the “Start” key for 2 seconds. The door will lock and filling will
begin. NOTE: The water will dispense for a moment, then the door will unlock
and re-lock and the cycle will continue.
i) Once the filling has begun again, open the dispenser drawer and immediately
add 1 cup liquid chlorine bleach to the main wash detergent compartment.
The liquid chlorine bleach should immediately flow through the dispenser.
NOTE: Do not add any detergent to this clean out cycle. Use of more than 1 cup of
bleach per month will cause product damage over time. Addition of bleach without immediately
starting the will cause damage to the product over time
5. Once the clean out cycle has begun, allow the cycle to completely run.
6. After the clean out cycle is complete, leave the door slightly open/cracked to allow
for better ventilation and prevention of future odor issues.
7. If you removed the detergent compartment divider, be sure to replace the divider
to the correct position.
NOTE: If necessary, the clean out cycle may be interrupted by pressing the “Pause/
Cancel” button. This will stop the cycle. A “Rinse and Spin” cycle must then be run to
thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage
to the unit and clothing added to the next cycle.
In addition to the clean out procedure, always do the following to prevent future odor
issues.
1. Use only High Efficiency (HE) detergent.
2. Leave the door slightly open after each cycle to allow for better ventilation and
drying of washer interior.
3. Repeat this clean out procedure only on a monthly basis, if necessary.
Posted on Mar 02, 2008
I have the same problem and my washer is just barely over a year old. I am completely unsatisfied and wish I would have never bought this washer. I noticed a tar like substance also and pulled back the seal/gray area and found a whole binch of built up sticky black grayish gunk and water there. I cleaned it the best I could but it was disgusting and I never had any problems like this with a top loading washer.
Posted on Aug 03, 2008
Tar like substance under alternator
On some alternators there is A vacuum pump. When the seals leak it does look like this
Oct 23, 2013 | Volkswagen Scirocco Cars & Trucks
I work in a factory where Iget a tar lke subtance on my shirts how can i remove this stuff ???
tar is removable by the use of house hold kerosene or mineral turps. scrub the affected areas with a solution then place in washing machine on full wash cycle.
Jun 22, 2013 | Office Equipment & Supplies
How can I remove tar from inside a washing machine's drum
Use mayonnaise, a sponge or a rag and some elbow grease.... My husband is a roofer and we always end up with some tar in the washer and dryer. So I just scrub it out with mayo. And do a soapy rinse afterwards in the washer, and if its in the dryer I throw a wet rag on a quick cycle to make sure there in no lingering mayo in the drum.
Oct 16, 2012 | LG Washing Machines
Black tar balls in Kenmore model #665.13722K600
No, don't run Coca-Cola in it! I would call a repairman immediately - you may have a rubber hose that is disintegrating, and you dishwasher could start leaking seriously!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 05, 2012 | Kenmore Dishwashers
When l looked at the reed valves. sitting on top of the valve was a broken piece of black plastic. what is it?
I find all kinds of debris inside of the head. Once I found what appeared to be tar but was a whole plastic bag that was sucked into the compressor and melted onto one piece of plastic sticky substance. Your piece could be a piece of the air filter left from mfg process. In another compessor, a clever mechanic used epoxy to try to seal one of the reeds on a multy reed plate to extend the life of the plate. In any event, glad to see that you are repairing it yourself.
Oct 20, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Tar like adhesive has gone sticky round speaker cones and volume has droped
The tar like sticky substance is the suspension of the speaker cone and there is nothing wrong with that. Its doping compound applied by the speaker company to damp the speaker ( Was it not always there? ) If the suspension has come off the bass notes will flutter, if not its some other problem. Play some music and put your ears near the tweeters flared horn to see if they working. Nearly 30% of your sound comes from the upper part and if you have damaged it there will be a volume drop.
These speakers are quite complicated on the inside. It has two amplifiers, one for the woofer and one for the tweeter. It also has a digital sound processor. Any thing could be at fault, even a simple wrong setting.
Mar 09, 2011 | Behringer Eurolive B212A Speaker
Tar clothing
I would think you would need to presoak the tar stained clothes in a bucket of hot & Stong detergent water. If you use that stong a detergent in the washer you run the risk of damaging the seals. Either do that or use someone elses washer and drier. Then Run like He..!
Dec 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
985 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
