I was just washing my hands, and Ericsson W580 was on the counter. It accidentally got splashed with water. I remember when i picked it up, there was water all over the screen. I wiped it dry with a towel and my shirt, but now it looks like there's water inside of my screen. I tried shaking it out... and it seems to be moving around because the screen is getting dimmer. Which is the opposite of what I want. You can see the light shining though and making shadows in my screen from the water. I'm scared this is going to cause even worse problems in the future. Everything seems to be operating perfectly. Is there anyway I can fix this and remove the water from my screen? Should i attempt taking it apart? I'm scared that I'll make problems worse. Please, help!
All of a sudden my screen in very very dim, have to strain really hard to see. I didnt drop it in water, just got dimmer. What can I do?? please help!!!
Comment by Guest, posted on Jul 02, 2008
I was on the phone with an all of a sudden the screen just went black the light was still on but it was just black like there was nothin on the screen but the ligh was still on
You're right in thinking it will cause you worse problems in the future. However if you take all the removable parts off, then give the phone a good 'shake dry' and try pushing down slightly on the screen to push out the water, then use an hair dryer on low heat to dry it, you might be lucky and save your phone from death.
Unfortunatly water and electricity (AC/DC) don't go well together.
Good luck.
Rating Locked! (?) wennz has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My Phone got wet, and the screen is starting to get dimmer.:
