Question about Kenmore Elite 45986 Front Load Washer
HE3t front door
I know that problem betwen CCU, MCU and motor, can somebody who knows what is the voltage in each pin tell me how can I check it?
I whant to know the voltage that sends CCU to MCU, and MCU to the motor. To identify which one is damaged.
Thank You for helping me.
    President:
  • 1,314 Answers
Send my an e mail at b4829@yahoo.com and my four boxes lol ill help ok job aid too big to send here
Posted on Mar 02, 2008
F06 code I know it its a problem with the motor drive and techometer and I want to know where it is located on the machine and what they look like can i get any images to help me
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
(tip courtesy JSRock)
Thanks for using FixYa#$%$%
Feb 12, 2011 | Kenmore Front Load Washer
My front load washer has an error code of F06, but my book doesn't tell me what that is, and the washer won't run
Thanks for using FixYa#$%%^
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Door won't open after a f-11 error
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Manual lock release:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 12, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore elite he3 but i get the error code F06 I don Know what means and how can I fix the problem?
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
Sep 07, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3t washer. Kept getting F11 codes. When I held cancel button nothing happened so I unplugged it. Problem is when I plugged it back in no lights came on nothing. What do I do? I already took...
Jul 07, 2010 | Kenmore HE2 Plus Front Load Washer
When the washing machine is almost done with the cycle--F11 comes on and I can't finish the cycle or open the door
In most cases this is an indication of a failed CCU.I usually Recommend a Repairman for this, as there is No way to check whether CCU is Bad or MCU is Bad or Both.
Note - Before Following the above Procedure, Do Unplug the Washer For Few Minutes, say 30 Minutes and then Turn ON. That would Reset the Machine.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite control board/motor board?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jan 27, 2010 | Kenmore HE3T Washer
Receiving Error Code F06 on my Kenmore HE3T Front Loader Washer. We replaced the Machine Control Unit and did not fix the problem?
Nov 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Does not start and shows 11H code
Aug 10, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
