While recording the ZOOM will automatically start to zoom. At one stage I thought that the problem was heat related because I noticed that I could stop the problem by heating the camera when it was cold say 6 deg C. but then it seemed that if it was hot I needed to cool the camera, but in the end I found that this was not consistent after many trials. Any help would be appreciated. Thank you Frank
Had an issue like that with my GL2 at an older stage. Ended up the dimmers and light combination would emit IR that confussed the camera into thinking I was using the remote control to zoom it... if it has an external (not in the lens) pickup you might try covering the IR reciever on the camera with dark tape (if you use masking tape or electrical tape, take it off after you are done as to not leave goop all over your camera)... a post it might work well. Otherwise look in the setup and turn off the remote if possible.... Just one possibility....
