Question about Saeco 762111651808 Espresso Machine
Brew unit hi, i opened the unit to clean it and now the brew unit wont go back in ? the light says missing brew unit ?
  • 515 Answers
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Posted on Jul 11, 2008
The brewer unit light seems to stay on and the coffee maker wont respond when pressing the coffee dispense buttons
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, (use a food grade lubricant) so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Aug 13, 2011 | Saeco Magic De Luxe Espresso Machine
Brew unit miss
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed (food grade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 21, 2011 | Saeco Royal Professional Espresso Machine
My brew unit indicator light is on - what do I need to do?
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing
Hi
Aug 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
The central unit LED blinks green and the machine does not turn on
Hi
The LED should be blinking red not green on a magic delux. The only green light is the boiler light for warming up or ready. If its the brew unit light it means its missing.
Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 09, 2010 | Saeco Magic De Luxe Espresso Machine
A red light is on.
Hi I think it is the brew unit if I remember right. Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit
Feb 18, 2010 | Saeco Magic De Luxe Espresso Machine
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
My machine grinds coffee without stopping for what seems a long time, then the bean light comes on and it will not make a cup of coffee. I took out the brew unit and cleaned it, now the brew unit light...
Hi
You have a couple things wrong now.
First you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder (towards the rear of the machine). Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side below the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
The second thing brew unit missing.
Open the door. Push hard on the upper left side of the brew unit. When you hear a click, close the door and the light should be out.
Nov 16, 2009 | Saeco Magic De Luxe Espresso Machine
Brew unit wont go back in ??
Check on the side of the brew unit there is a small N on it make sure the arrow is pointing at the N, clean rails in the machine then insert unit, do not press the lever when inserting unit.
May 05, 2009 | Gaggia Titanium Espresso Machine
Reads decalcify, brew unit missing- and wont make coffee!
Hi
Open you door on the right. Push on the upper left side of your brew unit and see if it will click. You have to push fairly hard towards the center of the machine. If it clicks the outlet pipe needs to be lubricated. The outlet pipe is the angled pipe on the top left side of the brew unit in the back. Lube the end of the pipe with food grade not food based lube.
Apr 27, 2009 | Saeco Royal Digital Plus Coffee...
Saeco 762111651808 Espresso Machine Logo
763 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
