Question about Xerox DocuColor 12 Printer
Tray 5 Diabled
I am trying to print some business cards on a 12pt/247 g/m2 card stock, 11x17 sheet, using the bypass tray 5.
it says tray 5 disabled, any one faced the same issue?
  • 2 more comments
  • ozoprint1 Mar 02, 2008
    Hi John, thanks for the info.
    My problem is is related to tray feeding, this link explains how to improve print quality.
    For some reason my tray 5 ( manual feed ) is getting disabled in Xerox DC 12.
    Any info you have?
    the error code is 7-286 : lift motor problems. output component test coede: 008-040 does not work.
    Am i wrong with the code?
  • ozoprint1 Mar 03, 2008
    thanks...it gets disabled while printing. after printing few sheets.
    I cant find these instructions on this page.
    look at the bottom...the process or steps for using the tray 5 is given,,,,? I am not using the stapler.
  • 796 Answers
  • 2 more comments
  • isaac johny
    isaac johny Mar 02, 2008
    Under Copy Output on the Basic Copying tab,touch the Stapling & More button.
    On the Copy Output screen, touch the Collated(Staple Options) button
    Select the desired stapling option from the StapleOptions screen.
    Touch Save to return to the Copy Output screen.
    Touch Save to return to the Basic Copying tab
    Select any additional features desired for the copyjob.
    Place the originals in the DADF.
    Press the Start button.
    The copies will be stapled and delivered to theFinisher Output Tray.
  • isaac johny
    note
    Remember the following when selecting the Staple options
    Stapling options can not be selected when using Paper Tray 5.
    Sets of more than 50 sheets cannot be stapled. If a set contains more than 50 sheets and stapling is selected, it will not be stapled.No error message will appear.
    Documents containing different page sizes can be stapled if all of the sizes in the document are supported by the In-Line Stapler Finisher and the feed edge of each paper is the same length.
    For more information on using the In-Line Stapler Finisher, refer to the DocuColor 12/ Document Centre ColorSeries 50 In-Line Stapler Finisher User Guide.
  • isaac johny
    is it disabled permanently or does it gets disabled during printing??
  • isaac johny
    if it is getting disabled when you try to print
    then,
How do I make a copy using the bypass tray with card stock on the canon image runner 1310?
You have to select the paper tray(in this case bypass)when you make a copy.
Dec 10, 2014 | Canon imageRUNNER 1310 Printer
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
Can I print onto 5-1/2 x 14" paper
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
Nov 17, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    HP LaserJet 5550DTN jams at transfer unit
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Jan 06, 2009 | HP LaserJet 5500dtn Color Printer
    Selecting glossy for 11x17 in Bypass
    Hello Kmully,
    Wow! Nice Q. Many variables. I hope this helps. First, heavy 2 is for the heaviest paper and slows the machine down and will give better color reproduction and consistantcy.Second, you need to use the bypass tray to properly use all the settings available. So use heavy 2 instead of 1,and use the bypass (Canon calls it a multifeed tray in some books) tray for optimal performance with the heavy,glossy stock you are using. I hope this helps. Sincerely.........................SPINAL
    Apr 02, 2008 | Canon imageRUNNER C3200 Copier
    Repeated paper jam in fuser
    Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
    b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
    Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
    Their may still be some card in fuser causing jams.
    Please rate as FIxya or post back,
    Cheers
    S. :-)
    Jan 01, 2008 | OKI C5200n Laser Printer
    Xerox DocuColor 12 Printer Logo
    253 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Philip Hughes
    docukaaf
    Level 1 Expert
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
