Question about LG Shine KE970 Cellular Phone
LG720 PAIRING WITH NUVI-360 GPS BLUE TOOTH PHONE BOOK
I am unable to transfer phone address book to gps phone book, requires some sort of lg software or so? Can you advise, pls. will appreciate.
  • brianr66 Nov 15, 2008
    I don't know if you have Verizon or not. I have researched this problem quite a bit. I have a LG VX8550 Chocolate & a Garmin Streetpilot C580 & the phonebook won't transfer over either. It used to tell me it was sending it but it never did. Then I got an update from Garmin web update & thought "alright, it gonna work now". So I connected to my Garmin with my phone & lo & behold it told me that the phonebook connect was complete! Then I checked for the phonebook on my Garmin & it was not there. I am confused as to whether it is a Verizon issue or a LG issue. My wife's Motorola Razor V3m (with Verizon) transfers the phonebook just fine. My daughter's LG enV (first edition) transfers the phonebook fine also. WHen I hook up to my LG VX8550 via USB cable, I can view the phonebook entries with bitpim but not with QPST. I believe it has to do with the firmware that LG used on this phone and that the phonebook format is different somehow. Maybe it was done by mistake but I don't think anyone's in a hurry to fix it. I think it's a shame because it effects a person's ability to drive safely while using what should be a problem free-hands free device. I hope someone finds a workaround for it. Next business day I am calling Verizon to try to exchange this phone. I am a very unhappy camper.....
  • Terry
    Terry Mar 30, 2014
    I have a new LGMS500 problem with 2011 Nissan Murano with Nav.
    Brigadier General:
  • 7,752 Answers
Try the software that came with the LG SHINE or call your mobile provider and see if they can assist further as well.
Posted on Apr 06, 2008
Caw we pair 2 cell phones with different call numbers with our car gps?
nuvi 660 does not support mutiple phones pairing simultaneously over blue tooth.
However you can drop the old and add a new
Garmin Zumo 660 User Manual Changing The Proximity Points Settings
Nov 21, 2015 | Garmin Nuvi 660 4.4 in. Car GPS Receiver
Garmin Nuvi710 phone book detail does not match phone contacts
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
I have a Garmin nuvi 265W and cannot add phone numbers to my phone book. help?
the numbers are transfered from your phone hence upadate phone then "disconnect" phone from sat nav when done and re pair the phone as data is not stored in sat nav
Dec 27, 2009 | Garmin Nuvi 265W GPS Receiver
How do I edit phonebook names from Unknown
the gps extracted the information from your phone. so its the phone whichs needs the editing, the gps will not update till that number calls you again, remove not drop the connection from your gps and phone after you have edited phone book re-pair phone should update when address book transfers
Dec 26, 2009 | Garmin Nuvi 265W GPS Receiver
I can't get it to recognise mt blue tooth phhone connection
have you set your phone to being visible? in the blue tooth settings, if you have either the phone or gps needs software update , contact garmin fo rlist of phone that match
Oct 08, 2009 | Garmin nuvi 1300 Car GPS Receiver
I have a Garmin Nuvi 680 I would like to use it as a hands off cell phone in my vechile. I no little about blue tooth. How do I go about getting my cell phone to work with my Garmin. Thanks Joe
Hi Joe,
1. First, you have to turn your bluetooth function (power) on your phone on. See your phone manual.
2. On your Nuvi, press the wrench symbol, then the bluetooth symbol. Press the option to enable bluetooth on your Nuvi. You will know that it is enabled when you see the bluetooth logo at the main menu on your Nuvi.
3. While in the bluetooth menu of your Nuvi, press the ADD button. It will tell you to turn the bluetooth function on your phone, which you should have already done in step #1.
4. Your Nuvi will start searching for your phone and if it finds it, the brand name will show up on your Nuvi's screen. Select the phone model and press OK. It will then tell you the pass key code. On your phone it will ask if you want to pair with your Nuvi. Select yes and enter the pass key code into your phone. This is usually 1234.
That's it. Your Nuvi will say you can now make phone calls. When you unit is paired to your phone and the bluetooth is turned on your phone, you will see a telephone handset at the main menu. Press that and you'll be able to select options to speak the phone number, enter it manually, transfer your phone address book to your Nuvi, etc......
If your phone isn't recognized by your Nuvi, make sure you have the latest bluetooth firmware on your Nuvi. It can be updated with Garmin's webupdater program available on their website.
- Jim
SHARCNET-USA
Feb 19, 2009 | Garmin Nuvi 660 GPS Receiver
Blackberry 8320 address book unable to import to Garmin Nuvi 265TW AT the start of pairing it did import it but once blacberry out of connection  from garmin or disabled, when enabled pairing address is...
The address books may not be compatible with each other regardless of pairing or not. Best bet is to check on garmin.com in the support section. If it isn't they you can use the dial up on the GPS as well as any other enhanced features that require bluetooth services.
Feb 13, 2009 | GPS
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
LG Shine KE970 Cellular Phone Logo
799 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
