Question about Philips PH62080 Uni-Directional Microphone Microphone
Microphone isn't working with the computer.
I've plugged the mic into the correct jack and i've followed all the directions for how to work the mic on the computer, but it still isn't working !
i've made sure its on and all the volume is turned up .
what am i doing wrong ?
  • 3 more comments
  • Anonymous Mar 20, 2008
    not able to increase output. Does this mic have a battery in it?
  • Anonymous Aug 05, 2008
    my mic doesn't work when i plug it in the computer no voice comes out
  • sector311 Sep 28, 2008
    same here...........sucks too i was using it to record my music.........damn damn damn
  • Anonymous Oct 15, 2008
    thank you thank you thank you!!!!!!
    my microphone wasn't working, i had no idea why, it turns out that it was unchecked in the recording section of the control panel or something, i never would have thought to look there!
  • hotsause coleslaw Jan 20, 2009
    i just cant seem to get it to record ive checked my sound settings, its in the right jack, and its playing music like headphones if plugged into that jack. the mic works but not records..
  • 682 Answers
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Posted on Mar 08, 2008
BlueBird is a PHANTOM POWERED microphone. That is, your soundcard (or whatever the mic is plugged into) MUST supply 48 volts to power the mic. Some soundcards provide 'phantom power' of 5 volts. That's only enough voltage to power a 'computer mic' - you know, those little mics that are not much bigger than a pencil eraser. You need the full 48 volts to get the BlueBird to work. So - read the specs on your soundcard. If it doesn't provide 48 volts, then you need to buy a '48 volt phantom power supply' which will plug in between your mic and the soundcard.
Posted on Jan 23, 2012
2 Suggested Answers
moshal85
  • 10 Answers
SOURCE: Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Posted on Apr 29, 2010
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Hello, i've just bought a sure sm58 mic so i thought i would get a good cable to go with it, i purchased a (Planet Waves 10 feet Custom Series 1/4 inch XLR Balanced Microphone Cable) but when connected...
Where do you connect the 1/4 inch connector? At the same device (karaoke)?
Also check and report if the 1/4 inch connector is "mono" or "stereo"
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 16, 2011 | Shure SM58 Professional Microphone
Is there a microphone built into the recorder and how do you get it to work
If your recorder has a microphone-in jack on it you can plug a mic into it directly and that will be recorded as the signal to whatever you're recording to. Your local Radio Shack will carry the plug converters you'll need if your microphone plug is either too large or too small for your mic-in jack.
Good luck! William
Feb 28, 2011 | Audio Players & Recorders
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
The microphone jack of my Dell Inspiron 1100 seems to be malfunctioned. When I plug in a microphone, the other side does not hear anything. I tried several different microphones and none of them worked....
Check if the correct recoding device is selected on sound properties, and verify if mic is mute.Test mic using the sound recording program.
Try to uninstall and reinstall the sound driver.
Perform diagnostic on the audio using the drivers and utility disc. if mic is not working on the diagnostic tool then need to replace the sound card.
Mar 12, 2010 | Dell Inspiron 1100 Notebook
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Microphone Problem with Vista
Do you Have Any settings Via Control Panel Or Similar, to check to see if the mic isn,t Muted ?
I,m not too up on Vista but have experience With 95/98/2000 And XP.
I,d also assume that there is Troubleshooting facility with Vista.
Also Is the microphone plugged into the correct Jack/Socket ?
Mike @ Compurepair.
** Please do not rate this, until your problem Has been Resolved**
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
Philips PH62080 Uni-Directional Microphone Microphone Logo
3,265 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
