Question about Soundstream PCA1000D Car Audio Amplifier
Constast cycling sound from my stereo onlt its intermitent
Can any one tell me why even with the power off my stereo is making a wierd like almost cycling noise.slickslickslcikslickslickslickslicklsick. I have cheked the wires and the amp and batt. the only way i have been able to make it stop is by un plugging the door speaker wires from the amp.
  • 631 Answers
If the other speakers play after the door speaker wires are disconnected, the problem is likely a speaker wire shorted to the door. If the vehicle had OEM amps and you didn't bypass them, that could also be a problem.
Disconnect the door speaker wires from the amp and check for continuity from the speaker wires to ground. There should be none. Also check the resistance across the speaker wires. They should read approximately the same as the rated impedance of the speakers.
Posted on Mar 05, 2008
My sub randomly started making a loud humming noise. The stereo was not even on at the time.
The humming sound is 60 cycles or a harmonic thereof emanating from poor filtering in the power supply. Better get the supply serviced before the speaker gets damaged.
Mar 21, 2015 | Audio Players & Recorders
I replaced the stereo and now all kinds of wierd electrical problems
quite a common problem with computer controlled cars (have an ECU or similar to control engine, brakes etc)
unfortunately the only simple answer is to remove the new item.... even then, some faults might need "clearing" by a main dealer diagnostic machine
May 27, 2014 | 2003 Chevrolet Cavalier
Mic only producing static noise
look at the plug on the end, two black insulator circles means its stereo and needs to be plugging into a stereo jack, 1 black circle means mono and you can get a mono to stereo adapter at the dollar store
Apr 05, 2014 | SteelSeries Siberia V2 Headset Frost Blue...
Wierd problem with my subwoofers please help
It sounds like your RCAs are pickin up noise somewhere, are your rca cables next to your amp power wire? this could be the problem. Just recheck your signal wires and make sure they aren't close to any significant power cables. Also does the noise only come from your subs or your car speakers to? If it comes from all your speakers you may have a headunit problem... hope this helps
Sep 30, 2009 | Orion 12DVC Car Speaker
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Dewalt 988 wierd trigger action
You will need a new trigger switch, parts are available at this link
http://www.dewaltservicenet.com/
thanks for using Fix Ya
Please take the time to rate this solution.
Feb 03, 2009 | Dewalt Drills
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Soundstream PCA1000D Car Audio Amplifier Logo
60 people viewed this question
Top Soundstream Car Audio & Video Experts
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
