Question about Vacuums
Miele S528 Cord Retractor
I think the cord inside is not making contact. How do I get to it?
I've removed screws, tried prying gently, but no luck.
Any advice much appreciated.
P.S.
Once the top is off, how do I reconnect the cord?
Thank you
Roman
  • pomko Mar 03, 2008
    Thanks for your reply, but still no success.
    I've taken out 5 screws but still can't take it apart... 2 at the front near the handle, 3 under and around the filter.
    I can't remove the control panel to check under it for any screws. Any suggestions?
    Thanks
    Found the screws.
    I just pulled the panel straight up and it came off.
    Thanks for your help.
    Roman
    President:
  • 1,673 Answers
There are some screws not removed yet, on the top under the filter there may be one, sometimes there is a screw under the control panel. Maybe these pix's will help. Most likely you will have to replace the cord reel asm (#05240303). You can take the reel apart and re-attach the cord, but if the spring unwound, then it maybe better to replace it.
Posted on Mar 02, 2008
  • Lauren Junge
    Lauren Junge Mar 03, 2008
    That control panel comes off, if I had it in front of me, I could figure it out. Some had catches or tabs on the back of it, they lock into the casing. Should be a couple of screws on the front part of it, which you may have already removed. And am sure there is atr least one screw under it. Wish I could nelp more.
Think cleaning lady pulled too hard on cord...now no power, doesn't turn on
it is possible that the cord rewinder has become broken inside the unit. It is a common problem with this and other models by Miele.
There IS a fix to the cord rewind, unless your model falls within the 5 year warranty. In which case contact your nearest Miele dealer for a replacement to the cord rewinder.
Good luck.
Nov 19, 2010 | Miele S514 Solaris Electro Plus Vacuum
My Miele S548 does not turn on. I am suspecting power cord contact inside. I am pretty good at disassembling electrical equipments including TVs and laptops. Not being able to open the vacumm canister...
heya,
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
Good luck,
Mark
Nov 11, 2010 | Miele S548 Bagged Canister Vacuum
Miele Red Star model S314. Cord reel is stuck. About three feet of cord is out. The rest of cord is jammed inside machine? How do I get to where the cord reel is?
It is actually simple when I tell you, Here we go...
First, open the lid and take the bag, and hepa filter out of the machine.
With a slot screwdriver, pry the hinges of the bag door out a little and take the bag door off.
You should see one screw holding the black black panel, remove that. When that is out, you can pull the black panel off. It will give a little resistance to you, do not be afraid of breaking it, it will come off.
Next you will see 4 or 5 screws down the holes there, remove all of them and the final remaining red piece will come off. When you pull this off, it will have both the cord rewinder and the motor assembly attached to it. It will be heavy becasue of the motor. Before you pull out the cord rewinder, just have a look at it closely and you may be able to just fix it without removing anything else.
good luck with it.
Nov 05, 2010 | Miele Red Star Bagged Canister Vacuum
Power Cord
Hi There,
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine. Unfortunately when this begins to happen, it's extremely difficult to fix this problem on the cord reel. It may be better for a short period, but it will continue to get looser, and looser until it finally won't turn on at all. It's really best to just go ahead and replace it at this point.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel. If you haven't already purchased one, here's a direct link to the exact cord that's needed for your S514:
Miele Cord Reel For All s500 Series #05240304
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please be kind and leave feedback for the repair. This is what continues Fixya repair professionals to continue giving free repair service rather then just doing the premium pay for repair help. This is really appreciated.
Thank you so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Miele Filtration Guard S528 Canister...
How do i disassemble (i.e. which screws do i pull and which hidden tabs are there) the cord retractor/switch assembly? there is only one screw that appears to hold the piece but it does not come out,...
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Sep 26, 2009 | Miele S514 Solaris Bagged Canister Vacuum
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
Sep 14, 2009 | Miele Vacuums
Artico miele vacuum cleaner power goes off and on while i vacuum.
Ok, that's usually directly related to the cord reel's contacts separating. I actually just posted this fix as a response to another thread, but here it is: It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Mar 06, 2009 | Miele S544 Artico Bagged Canister Vacuum
Miele s558 Silver Moon
Good luck,
-R
Aug 17, 2008 | Miele s558 Silver Moon Vacuum
The vacuum does not turn on when plugged in.
It could be either the switch, the motor, or the cord reel. Try plugging it in and slowly feeding the cord in and out while clicking the power switch on and off. If the motor kicks on while doing this, you have an intermittent short in the cord reel.
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off; on the s500 series you'll have to gently pry the tab just inside the hinge away,) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, (in many models, but it depends on your model...) which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
On the s300 series it is easiest to flip the machine upside-down after removing the top screws, and then lifting the base away from the top housing. This will give you access to the motor and the cord reel. On the s500 series you will just have to lift the colored plastic body up and away from the base.
What can occasionally happen with these cord reels is that they can wear out, allowing too much lateral slop of the actual reel assembly. You can shim this by using something on the axle in the center to push the reel assembly back against the contacts. I use a small rubber "doughnut," but pretty much anything non-conductive will do the trick.
If this doesn't restore electrical continuity, you'll probably need a new cord reel. I highly recommend against trying to do any further repairs on the cord reel itself, as it's a nightmare to deal with... especially if the main spring comes apart. Miele does not recommend replacement of any component of the cord reel, only the entire cord reel assembly.
Any other problems will have to be referred to a repair station, since it could then be either the motor or the motor control board.
Do NOT attempt to test the motor by directly connecting it to wall voltage, as the actual power applied to the motor when it is functioning is stepped down by the circuits attached to it, and attempting to "hotwire" it will fry the motor.
Hope this helps,
-R
Aug 09, 2008 | Miele Vacuums
Miele .s5210 Bag Vacuum
either the switch or the motor has burned out. try resistance test on each. look for positive resistance change on switch and about 2 ohms on motor. also look for a disconnected wire
May 26, 2007 | Miele Red Star Bagged Canister Vacuum
Vacuums Logo
831 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
