Question about RCA HD52W56 52" Rear Projection HDTV
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
  • Jaynab Mar 05, 2008
    This is amazing. I have the identical problem wit my Samsung PCK5315R. Mine went dead after a power surge. I plug it in and it sounds like its turning on and the red indicator light goes on for about 5-10 seconds. But no picture or sound when trying to turn on manually or via remote.
Posted on Oct 11, 2008
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Samsung Flashing Lights
a new lamp is possible or even the ribbon cable from the wheel to the engine may be in backwards.
Jun 14, 2012 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Turn on lamp blinks several times.lights up but no any remote button timer in green turns off and goes to standby
    The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
    Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
    Samsung projection tv
    change lamp change fans
    and replace color wheel.
    make shure to remove jumper when replacing samsung color weel.
    the jumper is black on the back panel of dmv modual.
    jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
    Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
    The problem is when i turn on the tv it automatically missing
    Usually when there is no lamp lit, there is an indication on the front with the timer/standby lights blinking or on. Are there any indications at all?
    Dec 04, 2008 | Samsung DLP HL-P5663W 56" TV
    Samsung PCK5315R TV
    I have the same problem have you figured out what the problem is
    Jul 31, 2008 | Televison & Video
    RCA HD52W56 52" Rear Projection HDTV Logo
    160 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
