Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Garage Door Opener Problem
HELP! I've changed the worm dirve and sprocket and now I can't get the door to go more than 2 feet in either direction. I've disconnected the limits switches to troubleshoot and I've also removed the chain. The motor runs one way a couple seconds and then reverses.
  • 4 more comments
  • lftmstr1245r Mar 12, 2008
    I have the same problem. I messed with it enough so that the garage will open all the way. However, it will only go down for 2-3 seconds and will go back up. I don't think the sensors are the problem because the light doesn't blink when the garage goes back up.
  • bentonmj Apr 16, 2008
    Man, am I glad to find this post! I just swapped out the gear set on my Craftsman opener, plugged it in, and had exactly the same thing happen. Even without the chain on, the motor runs one way for a few seconds, then reverses for a few seconds, then stops. I can't find anything miswired, misassembled, etc, although that doesn't mean it isn't. Has the posted solution worked for anyone?
  • Nokhodi Apr 19, 2008
    Craftsman garage door opener was working well and all of the sudden started to malfunction; goes up (or down) a few inches to a couple of feet and then reverses itself. I uninstalled it to reduce/remove stress for testing, but it does the same thing off the ceiling. Lubrication made no difference.
  • poppy2four Apr 27, 2008
    To all who read this... The fix is exactly as posted. You have to make sure the cap over the spring washers is FULLY compressed. To compress it, I ran a channel locks down the shaft and compressed the cap over the spring washers down ALL THE WAY and then clamped the channel locks to the shaft to hold the cap in place while tightenting the screws The Key is that the black cap (RPM Sensor) cannot move in or out more than 1/16 inch or the unit believes it's got a problem.
  • benv Aug 29, 2008
    Same problem. I checked that rotary flags that runs between the U shaped sensor. The door goes up and down few inches: That's all.
    I unplugged the sensor (A connector with 4 prongs); same thing happens.
    It seems like the sensor is bad...
    Any suggestions? Thanks: Ben.
  • bentonmj May 11, 2010
    lftmstr1245r's solution worked like a charm. The piece he's talking about is the collar that holds the bearing and washers on the motor shaft. It's held on the shaft by 2 set screws. Loosen them, push the collar so the spring washer is fully compressed (this is apparently what I failed to do), and retighten. I'm not sure how or why this worked, but it did. Thank you, lftmstr1245r!
  • 5 Answers
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Mar 12, 2008
  • Phat_Vinny Jul 09, 2011
    When I make the worm gear replacement with Sears' kits, the setscrews provided stuck out a bit from the collar. The door worked great but I didn't notice the setscrews rubbed on the RPM sensor board. Everything was fine for about 6 months then it would open 4" and then reverse. I have 3 door openers so I resorted to the rob Peter to pay Paul troubleshooting. I found the RPM sensor board was the problem. The emitter diode had been rubbed until the solder joints broke. I cleaned and resoldered the connections. Before reassembly, I used my dremel to grind the setscrews down even with the collar. It works fine and quiet. I made the same mod to the other 2 openers.
OK...thanks to
lftmstr1245r...he got me on my way. However....mine was an older model...vintage 1990 + or -. I ordered the repair kit..(screw drive, gear assembly, etc). When reassembling the screw drive, my original set up ONLY had the black cap. There was no top metal piece with two allen screws. So I included the metal ring with two screws, put the black cap on...and ran into the sameproblem..up one foot, down one foot. Worked on it for about an hour, came in, and read lftmstr1245r's post. However, seeing as mine didn't have the metal ring to begin with....I removed it and put the black cap back on. It is working like a charm. One other thing...if you can remove the cover to the encasement, watch the adjusters underneath. It made it a lot easier...when the door goes down, it touches the connection on one side to stop it...when it goes up...it touches the connection on the other side and stops. That's all there is to it. Easier to adjust it this way and see how far the metal bar goes before it touches either sensor. Good Luck.
Posted on Apr 26, 2008
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster Garage door model 3280 and I changed the belt and when I try to open the door it only open about 2 feet from the floor.
Remove the belt and then run the opener until the sprocket on top of the motor runs in the counterclockwise direction and stops. Now with the door in the open position replace the belt. Some adjustments of the up and down limits will be necessary.
Sep 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
We replaced the gear and sprocket in our sears craftsman garage door opener and now it will only open about 3 feet and then it reverses. Any ideas?
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Mar 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Model# 13953919 not working.
Yes replace the entire assembly. The part number is 41C4220A Sprocket and Gear Assembly and is available at Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener closes 2 feet and retracts back
Pull the release rope, see if the opener will complete its travel without the door connected. if so, the door is causing the fault. let me know what you find
clarkco
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 2 feet and then closes in same cycle
There is an issue with the limit settings. They are the three white screws you can see with the cover off. Put the door in the down position. take the small white piece off the bottom of the gear and sprocket assembly. Turn the center screw until the silver "wing" is at the bottom position. Put the white piece back on the bottom of the gear and sprocket. Adjust the up screw until the door opens fully. Check the force settings. They both should be set on 4-5.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,985 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
