S-Video output How do i send a video out put via my s-Video
  • 2 more comments
  • Fritz Stoppelbein
    Fritz Stoppelbein Apr 07, 2008
    kinda same problem. I have tried the settings,will not send video out. I have tried Fn F8 and still nothing on TV. This has worked before but trying to restore to that date laptop will not allow. video works on laptop fine, and I can slide icons off screen, but the wall paper for the laptop never shows up on TV. Exuasted, can you figure this out. I have also updated the NVIDIA GeForce2 Go and still nothing. Thanks Fritz
  • shuk May 10, 2008
    I am using an SVHS cable, assuming that it is S-Video cable, to connect latitude D-800 S-video port to TV's S-Video port. But on Fn-F8 nothing happens. I can connect this laptop to TV using DVI, but i need to connect usin s-video to get both video and audio (the input selection on TV has S-video and two RCA ports for input-2, and if i use DVI, i can't get audio). Can anybody help?
  • skmsuyash Nov 11, 2008
    I have the same problem . . . No S-video or projector output . . . Need it for college though . . .
  • Anonymous Feb 08, 2009
    yes same problem fn f8 noting heping
    greets
    Geert
    from Holland
Try <CNTL>,<ALT>, and F2 at the same time.
Posted on Apr 06, 2009
  • 97 Answers
You’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need. The solution you decide on will be determined by your budget, and the prices and codes below are taken from here, so shop around and you may get a better bargain locally or online.
First, you need two separate cables for video and audio: S-video to S-video (£3.60, 35551), and Stereo 3.5mm plug to 2x RCA plugs (£2.80, 35491). Both cables are two metres long and longer cables are also available from the same site. Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter (£3.25, 35570).
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV
Posted on Mar 02, 2008
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
How van I send video via bluetooth from video?
put the video in camera album and send it as u send Image
Aug 27, 2011 | Orion Gadgets Car Charger for Sony...
How do send monitor signal to my tv
It depend on what input your TV has the what output the laptop has.
Ideally you would connect over VGA cable. Your Laptop is very likly to have a VGA out put but if your TV is old it may not have a VGA input.
If not you will need to connect Via S-Video cable which all TV's & laptops have. Note that neither VGA or S-Video will carry audio so you will need a seperate audio cable if you want the sound to come through the TV speakers. This is normall just a wire with mini stereo jack on each end.
Dont forget to rate me if this helps
Jul 31, 2009 | Compaq Armada M700 Notebook
Hi there I don'tseem to be getting any component video output. I am inputting virgin via optical input video 1, I get the sound and the box even displays virgin but no visual output?
Optical is for "audio only" you need to send Video from whatever source you are hooking up, ie. TV,DVD,DSS,etc. Use what the source has, if it's got Component Video out, use that, Don't use HDMI! still too many firmware issues! Make sure when you hook it up to the receiver that you hook it up to the same input as your audio, just on the video side. It will say DVD or DSS or CBL next to the green,blue,and red inputs. Hope this helps
Jun 21, 2009 | Sony STR-DG500 System
No picture from monitor out on Onkyo TX-DS898
I realize you may have already doubled checked but make sure you follow this from the manual:
If the satellite tuner / cable box is equipped with an S video output
terminal, connect it to the S VIDEO 3 (or 4) IN terminal with an S
video cable. If it does not have an S video output terminal, connect
its video output terminal to the VIDEO 3 (or 4) IN terminal using an
RCA-type video connection cable. You do not need to connect to
both the S VIDEO 3 (or 4) IN and VIDEO 3 (or 4) IN terminals. If
the satellite tuner or television has component video outputs,
connect them to one of the COMPONENT VIDEO INPUT jacks.
With the initial settings of the TX-DS898, the VIDEO 3 and
VIDEO 4 input sources are set for the COMPONENT VIDEO
INPUT 2 jack.
If the video connection is made at COMPONENT VIDEO INPUT
1, this must be changed at the Setup menu: Input Setup → Video
Setup → Component Video (see page 35).
Using an RCA-type audio connection cable, connect the audio
output terminal on the satellite tuner or television to the same
VIDEO 3 (or 4) IN audio jacks on the TX-DS898. Make sure that
you properly connect the left channel to the L jack and the right
channel to the R jack.
If the device has a digital output jack as well, be sure to also connect
it to either a DIGITAL INPUT (COAXIAL) or DIGITAL INPUT
(OPTICAL) jack on the TX-DS898 depending on the device.
With the initial settings of the TX-DS898, the VIDEO 3 input source
is set for digital input at the OPTICAL 3 jack, and the VIDEO 4
input source is set for digital input at the OPTICAL 4 jack.
If the digital connection is made at a different jack, this must be changed
at the Setup menu: Input Setup → Digital Setup (see page 33).
Apr 15, 2009 | Onkyo TX-DS898 Receiver
Blank screen -
Try going into the desktop properties, then go to settings and make sure the VGA Monitor is selected as an output.
Apr 14, 2009 | Compaq Computers & Internet
SONY DAV - S880 compact AV system
Sony.com may have a pdf downloadable manual available on line.
The standard way to connect Audio from a Receiver to a TV is to send a signal from the Tape outputs (RED & WHITE) on receiver via RCA cable to a Aux input (RED & WHITE) on the TV. Likewise, sending a Video signal from a receiver to a TV, is via a Co-Axial RCA cable , using a Video Out (YELLOW) on the receiver to a Aux Video Input (YELLOW) on the TV. An S-Video cable can also be used (in leu of yellow RCA cable) if available on both Receiver & TV.
Jun 10, 2008 | Sony DAV-S880 System
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Computers & Internet Logo
1,062 people viewed this question
Alun Cox
David Payne
David Payne
