Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
Network card is dead
I believe that my Presario has an integrated network card. I also believe that it may have taken a hit in a recent electrical storm. It stopped working but everything else seems to work. I've put a USB wireless device on it to get access to my network. I cannot disable the other card through control panel/system/hardware/device manager. It just goes into perptual busy state. Now I cannot install upgraded Norton Antivirus. It gets hung up on installing network drivers. I suspect it's hung up trying to get at the same network port. Is there any way I can hardware disable the network part of the multifunction card?
  • JPete Mar 03, 2008
    Fix it in bios...? Okay, how do I do that?
  • JPete Mar 06, 2008
    Thanks jmcdonald151. The solution that you provided seems to have done the trick. Easy to do and seems to have aleviated the problems I was having.
  • 121 Answers
You can disable it in bios settings if its onboard remember to save on exit
Posted on Mar 03, 2008
  • john mc donald Mar 03, 2008
    when you turn your pc ao press delete acouple of times as soon as you turn it on if this dont work try f10 once your in look through the pages til you find onboard lan or ethernet and disable once done press esc and f10 to save . please dont mes around with your other setting as this will affect your pc thanks
Compaq presario S3190UK wont start, it beeps
That beep usually means a hardware problem. Try first unplugging every external hardware, like printer, keyboard, mouse, external hard drives, etc. Try powering on, if you get the same result DISCONNECT THE POWER CABLE, and try opening the computer and removing the RAM Memory modules one by one, try powering it on after removing each, if you removed all and still get the same beeps put them all back in and you may need to try the internal additional hardware such as PCI/PCIe cards (Non-integrated network card, non-integrated video cards, etc.). If all of this fails take it to a certified technician as you may have a main-board issue. DO NOT REMOVE OR ADD COMPONENTS WITHOUT FIRST UNPLUGGING THE POWER CORD.
Apr 08, 2014 | Compaq Computers & Internet
I want to remove physically a network card in my pc GX270 but i dont know which one is network card
For newer systems, network cards are "integrated" in the motherboard. If you are sure that you have a seperate PCI network card device, It should look exactly like this. Check the locks before pulling them out. Make sure that the pc is off and no flea power. Touch the metal sides of the CPU casing as this discharges any static electricity which is harmful for any electronic device.
Hope this helps.
Jun 30, 2011 | Dell OptiPlex GX280 PC Desktop
We have purchase several desktop PCs for the offfice use.. theres r lot of common issues.. 1.most of the time system gets corrupted in a sense, system get restarted over and over again without prompting...
NO OS stated why skip that? XP,? SURE ITS CORRUPTED ALL ARE NOW. and will get works, dead now for 3 years at MS.
the coin cell battery is dead if time clock fails.
for sure the clock in BIOS screens !!!
the NIC chip, or the Ethernet chip can be on board
or an actual NIC, nic means network interface card.
SR2150NX (HP retired this for support)official.
10 years old at least.
some came with VISTA is it VISTA, be nice to say.
does have this old slow chip
Integrated 10/100 Base-T networking interface
on board, or has addin board, open case look?
see what board added,? like giglan card?
the HP site clearly shows this chip
Realtek RTL8100
the driver can be had at realtek
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
I run a system PCI sniffer to get all chip true names,
no screw driver need no mag lens to read chip tops.
or here
http://driverpacks.net/driverpacks/windows/xp/x86/lan
27million drivers now, happy hunting.
3 ways to get them here. (HP, chip maker, or way3 seen here)
http://www.pcdied.com/Drivers.html
the first chip to get working with PC that runs
is what RTL8100, but you cant because its dead LAN.
so only at a PC connected to the web can you get it
and move it to dead pc. dead LAN.
(called sneaker net in the old days) sneaking PC to PC.
Aug 30, 2017 | HP Compaq Presario SR2150NX PC Desktop
My screen goes blues screen of death when I turn on the network button. Is somethingn set up wrong or is my network card dead?
boot it up without the network, uninstall the wireless adapter from the Device manager, then restart your unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 04, 2010 | HP Compaq Presario V2030US Notebook
What brand or type of ethernet port compatible to Compaq presario 5000.
Intel Pro VM 10/100 is what network card HP/Compaq integrated into that computer's mother board.
Apr 23, 2010 | Compaq Presario 5000 PC Desktop
I have Dell Opitiplex gx270 it looks like there are no cards on board. Trying to connect to the internet, says no network adapter cards found. wont let click on to the internet. I have other cards, I...
The network card (also the sound and video) is integrated onto the motherboard on this computer. You probably just need to install the drivers. You can download the drivers from Dell here. Also make sure the onboard network hardware is enabled in the computer's BIOS setup. (If you didn't use a restore set from the manufacturer and just install Windows, you almost always need to install the drivers for integrated hardware.)
Mar 30, 2010 | Computers & Internet
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
House hit by lightning - Ethernet not connecting to router
Most likley the network card is bad. Check if you get any lights on the network card. If there are no lights get a PCI network card for the system. If you get the link lights it could be just corruption on the system. Try uninstalling and reinstalling the drivers.
Aug 02, 2008 | Dell Dimension 4600 PC Desktop
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
