NO RESPONSE FROM YAMAHA YST-SW305/205
I HAVE A MARANTZ SR-97 & DP870 WITH THE SUB CONNECTED THRU THE FRONT SPEAKER CHANNELS. THERE IS NO SUB RESPONSE. I ALSO TRIED TO RUN DIRECTLY FROM SUB OUT ON AMP, NO RESPONSE. WHEN RUNNING THE TEST TONE THRU THE AMP ALL SPEAKERS EXCEPT THE SUB RESPOND... CAN YOU HELP PLEASE?
THANK YOU
RON
BENKLER@MSN.COM
  • RobAndDiana May 14, 2008
    I have the same problem, except I am using the Sub Out through an RCA plug and sub isn't auto powering on. How do you diagnose this? I saw someone said with a multimeter. Where/how should I be testing?
    P.S. I also tried hooking up another source directly to the sub through the RCA jack and didn't work either. It should turn on if any signal is reaching the sub, not just sub 100 hz level audio, correct?
  • 1,512 Answers
Hi Ron,
It sounds like the sub is not auto turning on, or has no audio output, and or the sub driver itself has failed. Do you have a multimeter, and we can diagnose the unit? :)
regards
Graeme
Posted on Mar 02, 2008
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
Marantz a/v reciever sr-96 users manual i canot find it.
I found a partial copy, first 9 pages in pdf format. if you want it can email me here:
nasa.info@mail.com
Dec 17, 2014 | Marantz Sr-96,dp870, And Rc2000 Packa 5.1...
Sound is not loud
most yamahas have a setting to lower main speaker volume 10 db, accessed by the remote, or front panel controls in the settings.this is a very small sub, only a 6.5 inch driver and 100w.
sub placement in regard to the seating position is very important in order to get good bass response.
Feb 21, 2013 | Yamaha Yst-fsw050 Powered Subwoofer Black...
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
I recently purchased a yamaha YST-FSW100 subwoofer and plugged connected it to my HTR 6140. Subs woulld not work. How will Iknow which devise is not working?
Turn the sub on, then touch the end of the sub lead when you take it out of the back of the amp..it should buzz to show the sub is ok . If the sub is ok then go through the setup on the Yamaha and tell it there is a sub connected in the speaker setup.
Nov 07, 2009 | Yamaha HTR-6140 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
271 people viewed this question
 Grubhead
Grubhead
