Question about LG RH188
Cant read discs
Sometimes my rh188 reads a dvd disc and sometimes doesn't. Any idea if the laser becomes faulty and if it can be cleaned or is there a replacement unit that can be sourced at a reasonable cost.
The RH188 is only a year and 3 months old.
Thanks Lorna
  • Anonymous Mar 10, 2008
    My LG RH188 plays DVDs ok till halfway through - then locks up.
    It will **t play the back end of any DVDs
    Have cleaned lens but makes ** difference
  • gemkouk May 25, 2009
    Do you know any compatible dvd-writer unit to replace the original?
I had the same and brought it back and they replaced the DVD unit. After another 6 moths I had the same and they had to replace it again. I think LG DVD units are lousy.
Posted on Mar 31, 2009
My VBR-110 Vizio Bluray player says no disc when there is a disc. I've cleaned the disc, tried different discs, cleaned it, unplugged it for a long ass time, so I don't know what else to do.
It's the laser that is faulty. The laser retrieves information . Normally when you load a disc you will hear it speed up then slow down and as the laser reads the disc it sort of makes a noise like a small hiss or squeak.
i imagine yours will take the disc and then runs to full speed and after around 30secs you have the error message and it stops? . Depending on how your model loads the disc this can sometimes be the result of someone pulling open the drawer or pushing it shut. If it's self loading try getting a good disc cleaner .
They cost very little and it may be enough to clean the laser lense. So buy a basic cd or DVD cleaning kit . The disc will have small brushes on it to clean the laser .
Good luck
Dec 10, 2013 | Vizio Televison & Video
Every DVD I put in the DVD player says disc error. Why is that
good day
the cause is either the disc motor not rotating or the laser sensor is dirty. try to clean first the laser with soft fiber cloth apply gently sometimes due to sticky in some part. just let me know if it works or still doesn't read so i can give further solution.
Mar 22, 2012 | Televison & Video
Laser lens not reading disc.The disc spins,but i get no video,or audio when dvds ,or cds are played. Cleaned the laser lens didn't solve problem. Figured the laser pick up has played out.Can anyone help me...
faulty lens you will need a replacement depends on brand and price sometimes its cheaper to buy a new dvd player, i know its a throw away society but thats just the way it is
May 07, 2010 | Televison & Video
The Power DVD player does not recognize that there is a DVD inserted into the slot. Sometimes it does not recognize it at all and sometimes it does so after a half hour or longer. Anything that can be...
The most common problem that dvd players experience where a disc error occurs is that the optical lens is dirty. Over time dust and dirt accumulates on the lens and prevents the laser from reading the data on the disc properly. The following picture shows you an example of what the optical reading lens looks like.
The small glass bubble is the optical lens. The spindle is also shown where the disc sits on and spins the disc.
The next common problem is the discs themselves, they can become scratched or dirty and it does not really even have to be a bad scratch for it to effect the reading of the data. The picture below shows you an example of a cleaning kit.
You can clean the optical lens manually in dvd players or by using a cleaning kit which includes and cleaning disc and solution. The kits are also effective for cleaning your cd/dvd rom that are installed in computers. You can also purchase products that will remove scratches and clean your discs as well.
I would suggest you try cleaning your device and see if that makes a difference in the way it is functioning. There could be other problems that cause the disc to not play properly. You can learn more about these malfunctions and also get instructions on how to clean a dvd player manually in the links highlighted.
I hope this information helps solve the problem you are having. Please feel free to ask if you need further assistance.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Apr 03, 2010 | Dell (0F146) Internal DVD Drive
Not reading DVD discs
has it been reading DVD discs before? Also, does it read other discs apart from DVD's?
It is possible that your DVD drive's lens (laser) is weak. You can try to use a lens cleaner or cutton board to clean the lens.
Take care.
Mar 07, 2010 | Acer Aspire One PC Notebook
How to make ps2 read blue discs
This almost always happens if the lasers in your device are going faulty, either that or a thing called a "Quadrant Detector" is going the same way.. You see the software in an attempt to "read" over any scratches or imperfection on the disk, ramps the Current to the Laser Diode up & down, too much of this is NOT good for the laser, and detector at all, a few times would be OK, but often it is made to read them over and over again... well eventually those two components wear out, not actually fail but become damaged... this then causes these problems you are experiencing. you see, there are TWO lasers One for CD's & One for DVD's sometimes ONLY one will go faulty. usually the DVD one as this generally has more current to it anyway. Hope that helps explain why.
Feb 04, 2010 | Sony PlayStation 2 (PS2) Console
No disk found message
your dvd player just cant read the disc,lower priced dvd players do that sometimes.
Dec 05, 2008 | NexxTech Televison & Video
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
PLayback of anything
If it occurs on a specific disk (one or more but with the same discs) Maybe the disc is dirty: Wipe it clean. Some DVDs are very sensitive.. Also make sure you inserted a disc the unit cannot play (see the list in the user guide p. 6 - http://www.fixya.com/BrowseManual.aspx?mnlid=7920&prdid=232136&__PAGED_=6 ) If not: The laser lens in your DVD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lens cleaning discs are available at many electronics retail store. Sorry I can't help you more. Good luck!
Dec 08, 2005 | Panasonic DVD-F65 Multi-disc DVD Player
Open Questions:
LG RH188 Logo
651 people viewed this question
