SanDisk Sansa e260 MP3 Player Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sansa Fuze. There are two red circular icons on the screen next to the battery life icon. What do they mean?
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Feb 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
32938
Points
350
5helpful
2answers
Its a lock with an arrow circal round it near the battery icon
You phone has it's screen rotation locked so if you turn the phone on it's side the display does not automatically turn, great for reading in bed. Double clicking your home button so that currently running apps are shown then keep swiping these icons to the right until your iPod controls appear, you should see an icon with a circular arrow. Click this.
1helpful
My sansa fuze i plug it in to the computer and it doesn't recognize the device and i have tried all usb options on the device. What do i do it wont charge at all.????
When the Fuze can be switched on:
1. slide the power on switch shortly upwards to put the player on
2. hold the power on switch upwards for 15-20 seconds
3. release the power switch
Next try to switch the player on and see if it reacts normally.
Switch the player off again and try charging again, making connection to a computer.
When charging still doesn't start, disconnect the player from the computer:
4. slide the power switch downwards into the lock position,
forcing MSC mode
5. connect the player to the computer for charging in MSC mode
for a about 3 hours.
6. while charging use the Sansa Firmware Updater to check for
updates. When not installed already download the Sansa Updater
and run this execute file.
Updates for the player can only be performed in MSC mode.
The updater only works when you're logged in to the computer having administrator's rights and running Windows operating system.
MSC mode means that the computer sees the player as a removable disk. When in MSC mode, always disconnect through the icon "safely remove hardware" in the right corner below of the computer screen.
When the display of the player doesn't react at all after the reset and charging procedure, the battery of the player can:
a. be too far empty or
b. have a fast power loss.
The load of the power supply from the USB ports might be to weak to get the player charged.
When point a. is the case, an extra power adapter connected to a wall socket, providing more power, could help.
When the battery has had many loads it can be at its end of duty cycle. Then battery replacement will be required.
Need more help ? Just post a comment.
Need to download the driver for my sansa fuze, do not have a cd rom on my netbook to use the cd
The Sansa support site for the Sansa Fuze is on this site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/session/L3NpZC9naFVzVmRRag%3D%3D/sno/0
important
Take notice of the player's connection mode, see page 15 (=13 of the manual).
Install and update Windows Media Player 11 or other supporting media software on the computer, when transferring in MTP mode.
Always go through the safely remove hardware routine (icon in the right bottom corner of the screen) before disconnecting the player in MSC mode.
Updating the Sansa Fuze's firmware, getting user manual and media
converter can be reached by going to the Sansa Firmware updater
support link, see:
http://kb.sandisk.com/app/answers/detail/a_id/278
1helpful
2answers
How do i put videos on my sansa fuze
Sansa Video Converter can transform all common formats to MP4 video andMP3, OGG, WMA audio for Sansa. More importantly, Video Converter forSansa is easy to use by few clicks for both Sandisk new users andseasoned Sansa owners.
2helpful
Sansa fuse radio does not work
is the little speaker icon red? pless the play/pause button. It mutes the radio.
My pink Alcatel S319 has a phone icon with a red X on the screen
Means u have missed call, just check your missed call to clear red X
Jun 14, 2009 • Cell Phones
First battery charge after purchase
I would charge the Fuze fully before first use, actually this is what is recommended. You'll know when it is finished, as you will get a full green battery icon displaying.
The players are not fully charged when first shipped.
6helpful
2answers
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Sansa e250 Little red button (icon) next to the battery icon
if we talking about the same thing it means the batterys low. if not sorry.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
