Question about Lexmark X2500 All-In-One Printer
Stops haft way of print job jams up
Keepsjaming up
  • Anonymous Mar 18, 2008
    PAPER GOES HALF WAY IN AND STOPS AND THEN WILL NOT TURN OFF PLEASE
    Genius:
  • 2,035 Answers
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 25, 2008
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
Stop Printing
Hi and thank you for using fixya:
To stop your printer from printing while printing press stop or cancel in your printer control center. Also you can click stop or pause on your computer print dialog box,
1-right click on top of the printer
2- click pause on current job printing
good luck!!
Apr 08, 2010 | HP PSC 1350 All-In-One Thermal Printer
How do I clear a paper jam ?
just open the printer cover and switch it off the printer and try to pull out the paper slowly and cancel all the print job from print queue.for clearing the print job you can go to run window and type services.msc and the go to print spooler option just stop and restart the service.
Nov 16, 2009 | HP Photosmart D7260 Printer
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
Can't remove program from computer because task stopped during print task
you might have a print job in the spooler, right click on your printer icon, select open and right click on any jobs, and select delete.
Apr 19, 2009 | Office Equipment & Supplies
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Lexmark X2500 All-In-One Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
