Question about Boston Acoustics MicroMedia Computer Speakers
Annoying humming sound coming from subwoofer...
There was an annoying humming sound coming from our Subwoofer. When I unplugged the power cord and plugged it back in the sound stopped, as did all sound coming from the speakers. I was able to shut down the computer and restart, and had sound again. But then last night same problem. Now I cannot get any sound from the speakers. My fear is the speakers are shot, we have had them for some time. Just wanted to make sure there was nothing else I should try before buying new?
  • JeffC1 May 17, 2008
    I have the same issue, anyone have a fix for this?
    Sergeant:
  • 291 Answers
The humming sound usually comes from the DC supply that is not filtered. The a/c converted or changed to DC needs to be "cleaned", before going into the ckt. Usually the capacitor and resistor network go bad, maybe causing the fuse to open. Even if you replace it, u may still have the "humming" because the circuit is still bad.
If you know how to look at the capacitor, resistor,or coils AFTER the diodes & replace the damaged part, u should be good!
Posted on May 18, 2008
Subwoofer is hummig what is this noise
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
Hi, I get a buzzing sound coming from my s8.3 when it's plugged into the power outlet. No other cable are connected, it's only plugged into power outlet. Any suggestions? thank you!
I also had a severe hum or buzz that was NOT a ground fault loop issue or any other such problem.
Hummed to the point that reading in the family room was annoying !
I took my amp to a Very Qualified shop and the technician simply insulated the transformer 40.00 usd
Nov 19, 2010 | Energry Speakers Energy Speakers S8.3...
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Dec 29, 2009 | Sony STR-DH800
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
Boston Acoustics MicroMedia Computer Speakers Logo
808 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
