Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
Power supply hookup
Hooking up connectors to right areas in cabinet,they have p nos on them just want to be sure
  • Anonymous Mar 02, 2008
    at end of power supplt the connectors are labelded,b6,b8,b4,b2,b5,b3 not sure where they go some r 6 wire and some are 4 wiring had to2 crossed fform floppy drive to hard drive??? i had it wrote down and lost notes. ordered new hard drive from western
  • 97 Answers
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Im trying to find the power supply hook up for the dishwasher
The power supply hookup on a dishwasher is located underneath and to the fromt of the dishwasher. Look at the very bottom front of the diswasher, where the toe-kick would be on your cabinets. You will see that this is actually a removeable panel held in place with a couple of screws. Remove this panel and you will see a metal box, also with a removeable cover plate. Remove this cover and you will find the power supply wires. Strip the wires from your Romex supply line and wire nut those to the dishwasher wires, blcak to black, white to white, and the ground will loop under a green grounding screw located in the inside of the box. Hope this helps.
Apr 30, 2011 | Dishwashers
My pc doesnt do any beep and does not send any video at all
With SLI you may need to ensure you hook the additional power connector from the power supply to the SLI video card. TYpically, these cards require a power hookup.
Sep 21, 2010 | Evga nForce 750i SLI Motherboard & Intel...
How do i hookup sata dvd drive
You should have been supplied a SATA cable if you have bought a new DVD drive. On your motherboard you will see 2 orange connectors just underneath where the older IDE grey cables plug in. Thesae are you 2 SATA connectors. They will be labeled as 0 and 1, if you are not using of these at moment connect to SATA 1 incase you decide to hook up a SATA HDD drive at some stage. Power cable just plugs in as usual. If PC doesnt recognise the drive you will need to go into the bios ( press DEL or F2 at startup) and it will be listed under something like drive configuration and just enable SATA there.
Jan 20, 2010 | MSI 661FM2-LSR Motherboard
I have a HP-Pressario 10 Desktop which had the cables from the 250 watt power supply unhooked. I need a diagram to rehook the cables correctly. This is a 20 pin hookup.
well the PSU cables for the mobo should only be able to be hooked to one place on the board. i'm not sure if this is a 20 pin and a 4 pin or just a 20 pin, but the 20 pin connector should only fit one place and snap in. you don't need a diagram, if you're wondering about all the rest of the cables it doesn't matter where you plug what 4 pin connector to. as long as they're connected..
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Oct 02, 2009 | Compaq Computers & Internet
I unpluged my fans and dont remember where they hook back up
if they have a 3 pin hookup you can plug them into any matching connector on the motherboard.
If they are the larger 4pin then plug them into any matching connector off of the power supply. Make sure the computer is powered off while you do this. Also dont worry, they are all 12v and you can even get 3pin to 4 pin adapters to connect them straight to the powersupply also.
Sep 12, 2009 | Computers & Internet
Power button hookup confusion
hey there
It easy to insert the connector of Reset, Power, And LED
Becuse everything is used to be properly written ur motherboard,
Checkout for the lower left corner of ur motherboard.(Behind the FDD Connector's right corner)
Hookup the connection by reading on down of the every PINs on your board.
Gimme
Aug 03, 2008 | MSI 651M-L Motherboard
No Power
Dear Sir,
I assume, you have voltmeter with you.
Set VOM to DC 20 V range.
Remove the Power Supply from cabinet. Be sure you have proper earth in your house/workshop.
On the 20/24 pin main connector of your power supply, short the pins carrying green & black wire.
Hook your voltmeter -ve on any black pin of the connector permenantly.
& then connect the mains power cord to your power supply.
If your power supply is ok, this shall start the fans of the power supply on & running. Now you can check the voltages on different pins. There is a sticker on your power supply showing the normal voltages on every wire.
If you don't see any / normal volatges, your power supply needs repairing. You can buy a new one/ repair existing.
Jun 17, 2008 | Silverstone SST-ST405 (SSTST405) 400-Watt...
I NEED A POWER SUPPLY FOR MY DEMENSION E520 DESKTOP
hai
find out if it is AT or ATX cabinet
AT cabinet will have a power ON/OFF switch just like a 2 way switch
ATX cabinet will have soft switch for ON/OFF
Mostly all the new cabinets are ATX type.
To make it sure, open the cover and check the power connector to the motherboard. If its a rectangular double layer connector, it is ATX power supply, on the other hand if its a two piece single layer connector, it is AT power supply
hope this information will solve your problem
good luck
Jun 17, 2008 | Dell Computers & Internet
Rca wsp155
There should be a mini connector (Male) connection to 2 RCA (MALE) Connectors. You just hook the output of computer (Mini) plug to that then hookup your RCA connectors usually white and Red to the transmitter and it should work fine. Try the premium area if you need further assistance. Guru Jay
Jan 28, 2008 | RCA WSP155 Main / Stereo Speaker
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
116 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
