Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
LED indicator There is a LED indicator above a tag or lock symbol with the letter "B" it is lit and the machine will not work. I have misplaced my manual and do not know what the indicator is for. Can anyone help?
  • CyndiK Mar 02, 2008
    Thanks. I did a little more digging and found it. I appriciate the speedy reply.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like the control lock feature has been activated. look closley at the buttons one with the" lock" light hold in for 3 to 5 secs and it should dissapear
Posted on Mar 02, 2008
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
Orange led on my LS4278
may indicate a temperature fault on battery.... here is your manual.....
https://docs.symbol.com/manuals/6983501c.pdf?userId=37
Jan 14, 2014 | Symbol LS 4278 Barcode Scanner
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
Lenovo a3000-k letters i o p j k l m plus some symbols will not type,the red numbers or letters underneath come up how do i get them to work
NUMBER LOCK
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator..
Jan 16, 2013 | Computers & Internet
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
MY MACHINE IS IBM THINKPAD X40 THE PROBLEM THAT I HAVE IS THAT WHEN I TYPE LETTERS LIKE K;L;J THAT HAVE SMALL NUMBERS DOWN IT GIVES ME THOSE NUMBERS INSTEAD OF WRITTING LETTERS I WOULD LIKE YOU TO HELP HOW...
The NumLk has been selected anf the NumLk LED is on to show that the NumLk has been selected.
Press the ScrLk/NumLk key to turn off the NumLk, this key is above the F11 key.
Feb 18, 2011 | IBM ThinkPad T30 2366 Notebook
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
buttons at the same time for 3 seconds.
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
Jan 11, 2011 | Samsung WF218AN Front Load Washer
Keyboard is stuck in numeric mode. Can't type
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Oct 02, 2009 | Panasonic Toughbook CF-51 Notebook
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
121 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
