Question about Kenmore 51252 / 51254 / 51259
Strip between freezer & fridge
The metal strip between the fridge and freezer is very very warm...every so often is cools for a few mintues, but heats up again....the water dispenser and ice maker are working, but the red light on the ice maker control keeps flashing
  • Kenmore Master
  • 2,651 Answers
Light falshing is normal, the strip between being hot is not though, remove the kickplate from under refrig and vaccuum the coils, pull unit out and clean behind, while there make sure that the fan adjacent to compressor is running(when compreessor is on). clogged condensor =hot mullion stip. not a major problem
Posted on Mar 02, 2008
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
Nov 06, 2017 | Refrigerators
I have a Kitchen Aide KSRS25ILBT02 Side by Side and the metal strip (mullion?) between the freezer and the refrigerator is hot to the touch. Hot enough to cause a burn if you leave your finger on it for...
You have a defective defrosting strip. A hearing element that warms the side of the fridge to melt ice that collects. Your fridge is dangerous to operate. You have a possible short in the defrost system that can electrocute you. You should unplug immediately. I am SERIOUS.
Aug 03, 2014 | KitchenAid Refrigerators
Horizontal fridge freezer - Freezer over-heating
The door frame has a heater to stop ice forming around frame. This is normal. You don't notice it when freezer is cold. The freezer should start working again.
Nov 01, 2009 | Freezers
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Our fridge model has the freezer on the bottom. When the fridge door is open, the front of the fridge above the freezer compartment is hot to the touch - also had a one time incident where the...
It is normal for the strip between the freezer and fresh food compartments to be warm to the touch. It's called the mullion strip and uses gas from the compressor discharge line to prevent moisture from forming there. Older models used an electric heater to do the same thing.
As far as the one time operational's a bit difficult to even guess not knowing the brand and model. Talk to us if it fails again.
Aug 20, 2009 | Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
160 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
